503 error Raspbian + Oracle
Postby haribos » Tue Jan 22, 2013 5:40 pm
I've installed Raspbian "Weezy" soft-floated to run:
Java(TM) SE Embedded Runtime Environment (build 1.7.0_10-b18, headless)
Java HotSpot(TM) Embedded Client VM (build 23.6-b04, mixed mode)
I've installed a clean Subsonic server, but recieve an
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/index.view
Powered by jetty://
This is the subsonic_sh.log output
[GC 1392K->525K(4992K), 0.0425600 secs]
584 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@f7d41f: display name [org.springframework.context.support.ClassPathXmlApplicationContext@f7d41f]; startup date [Tue Jan 22 16:29:47 GMT-01:00 2013]; root of context hierarchy
[GC 1930K->971K(4992K), 0.0390450 secs]
1467 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
[GC 2368K->1342K(4992K), 0.0354920 secs]
[GC 2750K->1671K(4992K), 0.0209610 secs]
[GC 3079K->2016K(4992K), 0.0239010 secs]
[GC 3424K->2420K(4992K), 0.0187230 secs]
[GC 3828K->2913K(4992K), 0.0333810 secs]
[GC 4321K->3343K(4992K), 0.0270930 secs]
22295 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@f7d41f]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1ee8099
22492 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1ee8099: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
22831 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
[GC 4751K->3713K(5248K), 0.0280290 secs]
[Full GC 3713K->2299K(5248K), 0.1704470 secs]
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/3105
23597 [main] INFO org.mortbay.log - jetty-6.1.x
[GC 3963K->2761K(5504K), 0.0195240 secs]
[GC 4425K->3170K(5504K), 0.0296950 secs]
[GC 4834K->3179K(5504K), 0.0130100 secs]
25891 [main] WARN org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@c20151{/,jar:file:/usr/share/subsonic/subsonic.war!/}
java.util.zip.ZipException: zip file is empty
   at java.util.zip.ZipFile.open(Native Method)
   at java.util.zip.ZipFile.<init>(ZipFile.java:214)
   at java.util.zip.ZipFile.<init>(ZipFile.java:144)
   at java.util.jar.JarFile.<init>(JarFile.java:152)
   at java.util.jar.JarFile.<init>(JarFile.java:116)
   at org.mortbay.jetty.webapp.TagLibConfiguration.configureWebApp(TagLibConfiguration.java:171)
   at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1215)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:525)
26468 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
[GC 4843K->3281K(5504K), 0.0165230 secs]
27219 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
27647 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
[GC 4945K->3691K(5504K), 0.0363830 secs]
28130 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
Who can help me to solve this issue?
haribos
Re: 503 error Raspbian + Oracle
Postby hakko » Tue Jan 22, 2013 6:00 pm
Searching the forum for ZipException gives this: viewtopic.php?f=2&t=10129&p=44965
MusicCabinet developer
hakko
Users browsing this forum: Google [Bot] and 29 guests
