Installation help [SOLVED]
Postby TuckLive » Mon Apr 21, 2008 3:00 pm
I almost got Subsonic installed, but I need some quick help. How do you define the java enviroment variable to startup Tomcat? I'm a linux noob so try to explain in simple terms. Thanks
TuckLive
Postby TuckLive » Mon Apr 21, 2008 3:49 pm
I found a document that explained it. SOLVED.
TuckLive
