Personal Address not working correctly
Postby frankthefish » Fri Jan 25, 2013 12:50 pm
So I have subsonic working great on my internal and external network with the exception of the *.subsonic.org address. It seems that no matter what name I put in the settings it does not update my personal address. If I put Test.subsonic.org and do a ping- I get the same address as if I pinged www.subsonic.org. Port forwarding works fine- I can reach my server via IP or other DynDNS service.
Any idea? Can I change what address gets registered?
frankthefish
Re: Personal Address not working correctly
Postby bushman4 » Fri Jan 25, 2013 12:58 pm
The subsonic.org vanity name service is not a DNS service, it is an http forwarding service.
Pinging the name will always return the same IP address as http://www.subsonic.org.
When you connect to that address on port 80 (standard http traffic) using a known host header (like, in your example, test.subsonic.org) the server responds with a "301 - Temporarily Moved" message that contains a redirect to
http://your.http.ip.address:YourHTTPPort/YourContextPath
This allows people to connect to our server by just knowing the simple subsonic.org address and not needing to know the ip address, port, or context path.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
