Maintain Genre tags with Subsonic?
Postby chasmj3 » Fri Jan 25, 2013 4:29 pm
I want to use Subsonic to maintain my genre tags, but having read some posts, it appears that Subsonic uses lastFM's tags, and no updates are permitted, or at least no user maintained tags are allowed. What is the situation on this?
Thanks for any info.
C
chasmj3
Re: Maintain Genre tags with Subsonic?
Postby BKKKPewsey » Fri Jan 25, 2013 4:45 pm
Subsonic uses your genre tags. Some of the Mods I believe use Last FM integration.
Postby chasmj3 » Fri Jan 25, 2013 6:01 pm
Is there any way to add a new genre to the list like World so I can update existing tags?
chasmj3
Postby BKKKPewsey » Fri Jan 25, 2013 8:05 pm
Using the SS tag editor - no but you could make a request over in the requests section.
However I think most users use external apps to manage their tags and use SS as a "quick fix" solution.
i.e. You can define multiple genre's in most tagging/media organisers eg New Age/World which you can't do in SS.
Postby bushman4 » Mon Jan 28, 2013 12:50 pm
You can always type a genre into the genre field... you won't be able to use the drop down list and the "Set" button, but the genre tag for each song is just a textbox.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Users browsing this forum: Google [Bot] and 23 guests
