Raspberry Pi Jukebox with Oracle JRE
Postby Doping » Fri Feb 01, 2013 4:30 pm
here is my little problem.
Problem Description: Error in jukebox: java.lang.IllegalArgumentException: No line matching interface SourceDataLine supporting format PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, big-endian is supported.
Troubleshooting Steps:
- Copied the missing lib(libjsoundalsa.so) from openjdk to Oracle JRE
- Tested for available audio devices and ALSA is listed.
Playback Application and version:
- Jukebox Mode
Subsonic Version: 4.7 (build 3105) – September 11, 2012
Server Version: jetty-6.1.x, java 1.7.0_10, Linux (120.5 MB / 147.8 MB)
Hardware Platform: Soft-float Debian “wheezy”, Raspberry Pi
Java Memory Limit: 150mb
Output from ffmpeg:
ffmpeg version 0.8.5-6:0.8.5-1, Copyright (c) 2000-2012 the Libav developers
  built on Jan 13 2013 22:49:23 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
[mp3 @ 0x11bd660] max_analyze_duration reached
Input #0, mp3, from 'Madeon - Pop Culture (live mashup).mp3':
  Metadata:
    artist          : Madeon
    title           : Pop Culture
    Encoded by      : SUPER(C)
  Duration: 00:03:24.14, start: 0.000000, bitrate: 320 kb/s
    Stream #0.0: Audio: mp3, 48000 Hz, stereo, s16, 320 kb/s
Last ten log file lines:
[2/1/13 5:16:29 PM CET]    INFO   DaoHelper   Checking database schema.
[2/1/13 5:16:39 PM CET]    INFO   DaoHelper   Done checking database schema.
[2/1/13 5:16:40 PM CET]    INFO   VersionService   Resolved local Subsonic version to: 4.7
[2/1/13 5:16:46 PM CET]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Feb 02 03:00:00 CET 2013
[2/1/13 5:16:55 PM CET]    INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Feb 01 17:21:55 CET 2013
[2/1/13 5:16:59 PM CET]    WARN   NetworkService   Failed to delete port mapping.
[2/1/13 5:17:27 PM CET]    INFO   VersionService   Resolved latest Subsonic final version to: 4.7
[2/1/13 5:17:34 PM CET]    INFO   VersionService   Resolved latest Subsonic beta version to: 4.7.beta3
[2/1/13 5:17:46 PM CET]    DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/media/USBHDD1/Music/Madeon - Pop Culture (live mashup).mp3] [-v] [0] [-f] [au] [-]
[2/1/13 5:17:49 PM CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2/1/13 5:17:49 PM CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[2/1/13 5:17:49 PM CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press ctrl-c to stop encoding
[2/1/13 5:17:49 PM CET]    ERROR   JukeboxService   Error in jukebox: java.lang.IllegalArgumentException: No line matching interface SourceDataLine supporting format PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, big-endian is supported.
Doping
