media folder not found
Postby dangleburt » Sat Feb 02, 2013 10:46 pm
Like several other users, I find that Subsonic cannot locate my media folder which is on a Drobo NAS. The folder is mapped as Windows drive Z:/ but subsonic can't see it. Subsonice sees all other local drives on the machine. I've tried all the obvious solutions. ANyone have a nonobvious solution?
dangleburt
Re: media folder not found
Postby alphawave7 » Sat Feb 02, 2013 11:50 pm
viewtopic.php?f=6&t=4867
An account permissions issue..see 'Permissions to remote folders' in the link above. Cheers!
Postby dangleburt » Sun Feb 03, 2013 3:51 am
Thanks...but the word "permissions" doesn't appear anywhere on the page you mentioned, and the key links on that page are dead.
dangleburt
Postby BKKKPewsey » Sun Feb 03, 2013 4:29 am
If you follow the monroe link then you will find the permissions info.
However SS does not work with mapped drives so you will need to use the unc path name.
Postby alphawave7 » Sun Feb 03, 2013 5:49 am
BKKKPewsey wrote:If you follow the monroe link then you will find the permissions info.
Tnx BK...I should save that direct link rather than the thread link... :oops:
