Song played once fine but...
Re: Song played once fine but...
Postby soxtalon » Sat Feb 02, 2013 11:19 pm
Problem Description: I just d/l subsonic today and think it is great so far. I had a few weird problems though.
1st. I played a song through and then it was gone from my folders. I opened the folder to find that the extension had been changed to .mp3.old - No idea how that happened at all. I changed it back to .mp3 and it was fine. Then though I played a song all the way through and then when I tried to go back to it it played for a split second and then just stopped. I cleared the player, added the whole album and it still won't play the track. It played it once through no problem though.
Troubleshooting Steps: For the first, like I said I found the file and changed the extension. I tried to see if that was the same issue for the second but it was not. I deleted the playlist and reloaded it, I closed subsonic and restarted it.
Playback Application and version: I was playing the song from my chrome internet browser
Subsonic Version: 4.7 (build 3106) – September 12, 2012
Server Version: jetty-6.1.x, java 1.6.0_01, Windows Vista (57.3 MB / 148.9 MB)
Hardware Platform: Windows 7
Java Memory Limit:
Problem Filename: 16b. Live 2004\05. Karmalaa.mp3"
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines:
[2/2/13 6:02:14 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:14 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:15 PM EST]   INFO   StreamController   Got range: Range[1622016,1622016]
[2/2/13 6:02:15 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:15 PM EST]   INFO   StreamController   Got range: Range[1622016,3514797]
[2/2/13 6:02:17 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:17 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:19 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:19 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:20 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:20 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:21 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:21 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:22 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:22 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:23 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:23 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:02:24 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:02:24 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:03:09 PM EST]   INFO   CoverArtController   Created thumbnail cache c:\subsonic\thumbs\110
[2/2/13 6:04:41 PM EST]   WARN   CoverArtController   Failed to create thumbnail for J:\PLD\Music\E-L\Lord of the Rings Soundtracks\2011 - The Lord Of The Rings - Symphony\cover.jpg
[2/2/13 6:07:08 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\01. Nice To Meet You.mp3"
[2/2/13 6:07:13 PM EST]   INFO   StreamController   Got range: Range[5111808,5111808]
[2/2/13 6:07:13 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\02. S'Ok.mp3"
[2/2/13 6:07:15 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\03. Megaton.mp3"
[2/2/13 6:07:15 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\04. QPD.mp3"
[2/2/13 6:07:40 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:07:40 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:07:53 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:07:53 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:07:54 PM EST]   INFO   StreamController   Got range: Range[3514797,3514797]
[2/2/13 6:07:54 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\05. Karmalaa.mp3"
[2/2/13 6:07:56 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\06. Nothing But Trouble .mp3"
[2/2/13 6:12:49 PM EST]   INFO   PlayQueueInputStream   soxtalon listening to "16b. Live 2004\07. Heavy.mp3"
soxtalon
Postby BKKKPewsey » Sun Feb 03, 2013 5:34 pm
soxtalon wrote:I opened the folder to find that the extension had been changed to .mp3.old - No idea how that happened at all.
Nor do I :? It sounds as if you have some tagging or media management tool running as well.
With regard to problems playing a track that has previously been played - try clearing the browser cache in chrome (shift-ctrl-del)
That usually sorts that out.
soxtalon wrote:Server Version: jetty-6.1.x, java 1.6.0_01,
I think you also need to update your java install :shock: we are now on version 38 for 1.6.
Postby soxtalon » Sun Feb 03, 2013 11:44 pm
:P Yeah Probably..I didn't really notice how long it had been!
But ok, I will try that and see what happens :D Thanks!
soxtalon
Postby soxtalon » Mon Feb 04, 2013 4:10 am
I tried clearing the cache but it still didn't work :?
I switched to my wife's laptop and the song that didn't work previously now works again but it happened to a different track. It was strange. I shuffled and skipped the song accidentally and I play it and it will load for a split second but then stop. I can even have it go in the middle of the track for a second before it just stops. I played around within the album and all the other tracks worked fine. Its a really weird error
soxtalon
Postby BKKKPewsey » Tue Feb 05, 2013 3:17 am
That is definitely a cache problem but the problem is I think that we are dealing with both the chrome cache and flash cache. :?
One thing I forgot to mention was after deleting the chrome cache is to refresh the page.
To delete the flash cache see http://forums.adobe.com/message/4278569
Postby GJ51 » Tue Feb 05, 2013 3:36 am
That's a problem filename all right.
"\" is a path seperator, so putting it in"2004\05" may cause problems. The "." is supposed to only be used as an extension designator as in "filename.ext" Try setting up a test folder as X:\Music\testtracks\Karmalaa.mp3 and see if that solves your problem.
If your naming convention is dear to you, you might have to modify it to 16b_Live_2004-05\Karmalaa.mp3 or some other method that adheres to conventional filename rules.
Postby BKKKPewsey » Tue Feb 05, 2013 3:14 pm
@GJ
Its running on Windows so yes it is a path separator.
I am reading it as the 05 is the track number.
I have a number of artists with a period in the filename path e.g. S.U.N. Project\2003 - Experimental\01 S.U.N. Project - Dont Talk To Me.mp3
SS plays them np
BKKKPewsey listening to "2003 - Sexperimental\01 S.U.N. Project - Dont Talk To Me.mp3"
Postby soxtalon » Thu Feb 07, 2013 10:14 pm
Yes it is a path separator. The actual file was 5. Karmalaa.
soxtalon
Postby BKKKPewsey » Thu Feb 07, 2013 11:00 pm
soxtalon wrote:The actual file was 5. Karmalaa.
By Nuno Bettencourt I presume :)
Postby soxtalon » Sat Feb 23, 2013 1:46 pm
Indeed it is!
soxtalon
