Files not showing up
Postby ashemsay » Sun Feb 03, 2013 1:31 pm
Hello, I come to you because I can't find the solution to my problem and I hope you can help me. Here's the problem
Problem Description: In some folders, the files are not showing
Troubleshooting Steps: I went into the folders appearing empty via ssh and confirmed that the files are actually there. I chowned all my music directory to subsonicadmin:subsonicadmin (that's the user running my standalone subsonic) and chmoded it to 777, no change. I cleaned up the database and rescanned the media folders, no change.
In order to see all the files I had to move my Music directory (actually I created a symbolic link to that folder in /var/Music/MusicHMC and added a media folder for that location), after a scan, all files appeared. So i guess it has something to do with some database somewhere but I couldn't find any piece of information about that.
Playback Application and version: I use IE10 and firefox 18, same problem.
Subsonic Version: 4.7 (build 3105) – September 11, 2012
Server Version: jetty-6.1.x, java 1.6.0_24, Linux (64.4 MB / 117.4 MB)
Hardware Platform: Linux CentOS 6 64bit
Java Memory Limit: If that's the SUBSONIC_MAX_MEMORY variable in the startup script, it's 150
Problem Filename: For example, files located in directory
/home/files/Music/La_Reunion/BASTER/variété\ -\ Baster\ 01\ -\ Mouvman\ Kiltirel\ Basse\ Terre/
were not showing up. The files present in that directory are :
ls /home/files/Music/La_Reunion/BASTER/variété\ -\ Baster\ 01\ -\ Mouvman\ Kiltirel\ Basse\ Terre/
01 domin.mp3          06 oté kréol.mp3      11 afrik di sid.mp3
02 mo frer.mp3        07 réunion zordi.mp3  12 zanfan kréol.mp3
03 manzel vaudou.mp3  08 wayo momon.mp3     baster - tèn pa la vi.mp3
04 la montane.mp3     09 péscher.mp3        @eaDir
05 mon liberté.mp3    10 ti manzel.mp3
After creating the symbolic link and having a media folder pointing on the symbolic link, the new path became
/var/music/MusicHMC/La_Reunion/BASTER/variété\ -\ Baster\ 01\ -\ Mouvman\ Kiltirel\ Basse\ Terre/
and all the files appeared.
Output from ffmpeg -i: the command ffmpeg is unknown to my system, I assume because I have a standalone version. I did a find . -iname ffmpeg from within my subsonic dir with no results
Last ten log file lines:
[2/3/13 2:14:21 PM CET] INFO MediaScannerService Scanned media library with 21818 entries.
[2/3/13 2:14:21 PM CET] INFO MediaScannerService Marking non-present files.
[2/3/13 2:14:23 PM CET] INFO MediaScannerService Marking non-present artists.
[2/3/13 2:14:23 PM CET] INFO MediaScannerService Marking non-present albums.
[2/3/13 2:14:23 PM CET] INFO MediaScannerService Completed media library scan.
[2/3/13 2:14:23 PM CET] INFO PlaylistService Starting playlist import.
[2/3/13 2:14:23 PM CET] INFO PlaylistService Completed playlist import.
[2/3/13 2:14:23 PM CET] INFO PlaylistService Starting playlist statistics update.
[2/3/13 2:14:25 PM CET] INFO PlaylistService Completed playlist statistics update.
[2/3/13 2:14:44 PM CET] WARN CoverArtController Failed to create thumbnail for /var/music/MusicHMC/La_Reunion/BASTER/variété - Baster - Lèv po la pé - (2005)/07 - Fini ek sa.mp3
PS: Excuse my bad english, I'm french. Thank you for your help
ashemsay
