The compression procedure is not supported
Postby wirehack7 » Sun Feb 03, 2013 2:03 pm
I tried to download files via the zip function of subsonic.
After downloading this error occurs in 7z
How to resolve this?
Inside the zip file is a strange folder:
wirehack7
Re: The compression procedure is not supported
Postby wirehack7 » Sun Feb 03, 2013 7:04 pm
Okay, sorted out that this error only occurs on big files (a few GiB).
Any conclusions?
wirehack7
Postby bushman4 » Mon Feb 04, 2013 7:46 pm
More than 4gb?
From Wikipedia (http://en.wikipedia.org/wiki/Zip_(file_format)):
The maximum size for both the archive file and the individual files inside it is 4,294,967,295 bytes (232−1 bytes, or 4 GiB minus 1 byte) for standard ZIP
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby wirehack7 » Tue Feb 05, 2013 2:15 pm
Oh damn. Okay, that sorted it out!
Is it possible to mark a few files and download them with the download link above as zip, instead the entire folder?
wirehack7
Postby BKKKPewsey » Tue Feb 05, 2013 3:23 pm
Yes - in the more actions box
Postby wirehack7 » Tue Feb 05, 2013 8:32 pm
Oh. Now I feel a lil dump.
Thank you!
wirehack7
Postby BKKKPewsey » Tue Feb 05, 2013 9:54 pm
:lol:
