Cannot Scrobble to Last.fm from android
Postby FillCollinz » Mon Feb 04, 2013 4:45 am
I am new to subsonic and it has been working great. I am able to scrobble my listened tracks from my PC, however when I play tracks from my android it does not scrobble. One of the main reasons I decided to use subsonic is that I would be able to stream my entire music library while I am away from home AND that I would be able to scrobble the music I listen to while I'm away from home. Hopefully someone will be able to help me out.
FillCollinz
Re: Cannot Scrobble to Last.fm from android
Postby hakko » Mon Feb 04, 2013 7:53 am
The Subsonic server doesn't scrobble songs played from apps. The reason is that the server cannot distinguish what you're listening to, and what you're downloading for caching reasons (or listening to twice). You have to configure your app to do the scrobbling for you.
MusicCabinet developer
hakko
Postby FillCollinz » Mon Feb 04, 2013 3:15 pm
How do you configure your app to do the scrobbling for you?
FillCollinz
Postby bushman4 » Mon Feb 04, 2013 6:11 pm
Go into the settings of the Subsonic app and set your last.fm logon info in there.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby FillCollinz » Mon Feb 04, 2013 8:39 pm
When I go to settings of the subsonic app, under "other settings" there is a setting "Scrobble to Last.fm" which I have checked. That is the only place on the app that has anything about Last.fm
FillCollinz
Postby dazbobaby » Mon Feb 04, 2013 8:58 pm
You also need to setup "scrobble to last.fm" within the subsonic settings (PC). It's in the Personal section of the settings.
You also need a last.fm account.
dazbobaby
Postby FillCollinz » Mon Feb 04, 2013 9:11 pm
I did that. It will scrobble when I use the player on my PC, but when I listen on my android, nothing scrobbles.
FillCollinz
Postby bushman4 » Mon Feb 04, 2013 10:53 pm
In the mobile application... not the web interface. On your phone, go to settings, and set your info.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby daneren2005 » Mon Feb 04, 2013 11:17 pm
The clients don't have you directly input your credentials, you just have to check the check box which he says he already checked. I have no clue why it isn't working from there though.
Postby FillCollinz » Mon Feb 04, 2013 11:50 pm
I know, it's annoying. I am enjoying subsonic other than that. But scrobbling is very important to me. Is anyone else having this problem? Are other people able to scrobble from the android app no problem? I'm thinking about uninstalling the app and reinstalling it and seeing if that works.
FillCollinz
Postby daneren2005 » Tue Feb 05, 2013 1:31 am
Just checked and sure enough it is scrobbling correctly for me.
Postby bushman4 » Tue Feb 05, 2013 1:46 am
Likewise.
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby FillCollinz » Wed Feb 06, 2013 11:31 pm
Good news everyone! I got it to work. I logged in as admin instead of a user account that I had created the first time. Scrobbling beautifully!
FillCollinz
Postby Boulou » Fri Jan 24, 2014 10:37 am
I have the same problem.
Cant get the android app to scrobble... :(
scrobble is fine in the browser (using admin user)
in the android app the scrobble is activated and log in with admin user also.
Boulou
