stability issues after switching from windows to linux
Postby mpruett » Wed Feb 06, 2013 5:09 pm
Hi i have been using subsonic for a few years on my windows server with out any issues, i have recently switched to Linux Mint and have run into some stability problems with subsonic, after about about 3 or 4 hours of uptime it becomes non-responsive and i can not even bring up the web page, if i try restarting the service it will restart just fine but after the restart when i try accessing the webpage i get the following error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
a reboot will resolve and allow access to the site but then in about 3-4 hours it will crash again, the following is what i see in the log, and am unsure what is causing this, any help would be much appreciated.
[2013-02-06 00:07:49,297] WARN NetworkService - Failed to delete port mapping.
net.sbbi.upnp.messages.UPNPResponseException: Detailed error code :899, Detailed error description :Content is not allowed in prolog.
at net.sbbi.upnp.messages.ActionMessage.service(ActionMessage.java:179)
at net.sbbi.upnp.impls.InternetGatewayDevice.deletePortMapping(InternetGatewayDevice.java:417)
at net.sourceforge.subsonic.domain.SBBIRouter.deletePortMapping(SBBIRouter.java:61)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:167)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:309)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
mpruett
Users browsing this forum: Google [Bot] and 24 guests
