Installed windows version, no effect
Postby mntamimi » Sun Apr 27, 2008 11:48 pm
Am I doing something wrong?
I installed using the windows installer and followed the short directions from the install page on a windows server 2003 machine and got a little yellow submarine in the system tray, but I try both http://localhost/subsonic and http://localhost:8080/subsonic and get no results. I don't have much in the way of server experience, so maybe I'm missing something.
Also, the screenshots look great. Can't wait to try. Thanks!
mntamimi
Postby sindre_mehus » Mon Apr 28, 2008 4:58 am
I think it installs to http://localhost/ by default. You can also try to click on the submarine tray icon.
Postby mntamimi » Mon Apr 28, 2008 7:13 pm
Thanks for the response- I did try that one and it didn't work either, sorry forgot to include that. I tried all of the options available from the little box that comes up from the submarine in the sys tray.
I read through the forum and came across this post:
http://forum.subsonic.org/forum/viewtopic.php?t=1001
Is there an issue with Windows Server 2k3?
I navigated to the subsonic folder in the C: drive and tried opening pages that way, but that didn't work either. I feel silly since the install instructions were so simple, but I must be missing something.
mntamimi
Users browsing this forum: No registered users and 79 guests
