subsonic back up before system wipe ?
Postby kingzain74 » Fri Feb 08, 2013 10:39 pm
i would like to do a clean system install of windows 7 pro 64-bit , my only problem would be that i could lose all my subsonic info
what is the proper way of saving subsonic and all its settings so when i re-install it after my system wipe i will still have all my user accounts and settings ?
kingzain74
Re: subsonic back up before system wipe ?
Postby BKKKPewsey » Sat Feb 09, 2013 7:03 pm
If you save the c:\subsonic folder - wipe and reinstall OS - reinstall SS then replace the new folder with your old one.
Everything then should be back to as before.
