Russian and Norwegian characters
Postby Striff » Mon Feb 11, 2013 11:32 pm
I've got Fun_Plug 0.7 installed on my DNS-325 and subsonic installed correctly.
Everything working fine but i've got problem with some specials characters on Russian and Norwegian albums, it display only "?" and i can't play the files or can't see the folders that use this kind of chars.
As readed in some posts found in a couple of different forums, i've tried to add theses lines with differents settings (between the " ") but still not working :
export LANG=""
export LC_CTYPE=""
Is it a bug of the last subsonic version or is there something to do ?
Regards
Striff
Re: Russian and Norwegian characters
Postby Striff » Tue Feb 12, 2013 2:00 pm
For information, there's no problem when this chars are set in the Tag of the MP3/FLAC the display is perfect, the problem is only when theses chars are in the filename. :?
Striff
