chefdwsaute wrote:i did have about 7 or 8 users with their own username and passwords. from what i can see, it looks like i will have to add them again. is this correct?
but some abuse the privilege!GJ51 wrote:How are you connecting at work? Over their network wifi? When you use your phone is it using wifi or a cell connection. Workplace sometimes block connections and cell connections will sometimes timeout if the signal isn't providing enough bandwidth.
Also - we just had a brief outage of the subsonic.org redirection service a couple days ago. If you were trying to connect when that was happening that would explain a lot.
You might also write down your external ip address and port number in case it happens again and then try connecting that way.
