Subsonic Server is running...but getting 503 error.
Postby ksdiegel » Mon Feb 18, 2013 1:46 pm
So I posted a problem with a Podcast error the other day. Now...I can't even get into my subsonic application from my server.
I can get to other applications running on the server through browsers (ie. SharePoint), but SubSonic is totally not responding.
I have stop and restarted Subsonic a dozen times. The server has also been restarted.
The service icon is Green and indicates that it is running. The Control Panel says it is running.
But I can't get any browsers to connect to it.
I LOVE this application. Can anyone offer some assistance?
Here are the Log Files...I think they have some indications that something is not working correctly:
Agent - http://dl.dropbox.com/u/44512209/subsonic-agent.log
Service - http://dl.dropbox.com/u/44512209/subsonic-service.log
Root - http://dl.dropbox.com/u/44512209/subsonicLog%20From%20Root.log
Thanks in advance.
Scott
ksdiegel
Re: Subsonic Server is running...but getting 503 error.
Postby telijah » Wed Feb 27, 2013 10:02 pm
Bump for this problem. Coincidentally, I was farting around with Podcast settings as well. My logs show the same as the OP. If it helps, I did the following just before it all broke:
Podcast settings were set to save to c:\music\Podcasts
While it was downloading episodes for the first podcast feed I entered (so actively downloading to c:\...), I went back to settings and switched it to save to a different location. Then I tried deleting the podcast feed in question and was getting an Access Denied error. So I manually deleted the folder on the c drive, and am now getting what the OP shows...
telijah
