ldap url bug
ldap url bug
Postby yougotborked » Tue Feb 19, 2013 2:56 am
While defining ldap authentication under advanced settings, I got a
Error
Exception   java.lang.NumberFormatException
Message   For input string: "389ou=Users,dc=abork,dc=co"
Java version   Sun Microsystems Inc. 1.6.0_24
Operating system   Linux 3.2.0-4-amd64
Server   jetty-6.1.x
Memory   Used 60 of 147 MB
Stack trace   java.lang.NumberFormatException: For input string: "389ou=Users,dc=abork,dc=co"
   at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
   at java.lang.Integer.parseInt(Integer.java:481)
   at java.lang.Integer.parseInt(Integer.java:514)
   at com.sun.jndi.toolkit.url.Uri.parse(Uri.java:232)
   at com.sun.jndi.toolkit.url.Uri.init(Uri.java:138)
   at com.sun.jndi.ldap.LdapURL.(LdapURL.java:85)
   at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:164)
   at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:211)
   at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:154)
   at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:84)
   at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:684)
   at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:305)
   at javax.naming.InitialContext.init(InitialContext.java:240)
   at javax.naming.InitialContext.(InitialContext.java:214)
   at javax.naming.directory.InitialDirContext.(InitialDirContext.java:99)
   at org.acegisecurity.ldap.DefaultInitialDirContextFactory.connect(DefaultInitialDirContextFactory.java:180)
   at org.acegisecurity.ldap.DefaultInitialDirContextFactory.newInitialDirContext(DefaultInitialDirContextFactory.java:247)
   at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:123)
   at org.acegisecurity.ldap.LdapTemplate.searchForSingleEntry(LdapTemplate.java:246)
   at org.acegisecurity.ldap.search.FilterBasedLdapUserSearch.searchForUser(FilterBasedLdapUserSearch.java:119)
   at org.acegisecurity.providers.ldap.authenticator.BindAuthenticator.authenticate(BindAuthenticator.java:71)
   at net.sourceforge.subsonic.ldap.SubsonicLdapBindAuthenticator.authenticate(SubsonicLdapBindAuthenticator.java:72)
   at org.acegisecurity.providers.ldap.LdapAuthenticationProvider.retrieveUser(LdapAuthenticationProvider.java:233)
   at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:119)
   at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
   at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
   at org.acegisecurity.ui.webapp.AuthenticationProcessingFilter.attemptAuthentication(AuthenticationProcessingFilter.java:71)
   at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:252)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
this was my LDAP URL
ldap://ldap.abork.co:389ou=Users,dc=abork,dc=co
As you can see, I forgot the slash after the port number and then subsonic had a problem.
On a related note, can someone help me get ldap (openldap on debian) working. Are there any subsonic logs I can tail? I have sssd working across all my machines on my network, my ldap openvpn server in pfsense authenticates correctly. I am stumped on subsonic.
my ldap url is the same as above, except with the slash,
my search filter is
(uid={0})
yougotborked
Re: ldap url bug
Postby gurutech » Tue Feb 19, 2013 2:00 pm
I would think you don't need to specify the port number, considering you have the ldap: prefix on the URL...
gurutech
Re: ldap url bug
Postby yougotborked » Tue Feb 19, 2013 6:35 pm
tried it without the port, did not work
yougotborked
