0completely lost :(
0completely lost :(
Postby jwa1882 » Wed Feb 20, 2013 3:12 am
Ok, so I made it through some tutorial up until I change my login and password...then I get this message saying, "No media folders found. Please change the settings." Continue with the tutorial which seems to go along with this message....that's where I get lost! The screenshot's in the tutorial have way more options...specifically including the "music folders" option.
I was using audiogalaxy up until they got sold, and this seems to be the only other real option for streaming one's own music. That said, I had pretty much planned on donating. I went ahead and donated figuring maybe certain options weren't available yet...nothing...
I am running windows 7 64....
Tried searching the forums, but at this point I'm not sure what I am looking for! Any help would be greatly appreciated and a big thanks in advance!!!
also, here is a copy of the log:
[2/19/13 6:55:48 PM EST] INFO Schema46 Database table 'transcoding2' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema46 Database table 'transcoding2' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema46 Database table 'player_transcoding2' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema46 Database table 'player_transcoding2' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema46 Database column 'transcoding2.default_active' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema46 Database column 'transcoding2.default_active' was added successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Updating database schema to version 20.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'media_file' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'media_file' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'artist' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'artist' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'album' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'album' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'starred_media_file' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'starred_media_file' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'starred_album' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'starred_album' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'starred_artist' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'starred_artist' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'playlist' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'playlist' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database column 'playlist.imported_from' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database column 'playlist.imported_from' was added successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'playlist_file' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'playlist_file' was created successfully.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'playlist_user' not found. Creating it.
[2/19/13 6:55:48 PM EST] INFO Schema47 Database table 'playlist_user' was created successfully.
[2/19/13 6:55:48 PM EST] INFO DaoHelper Done checking database schema.
[2/19/13 6:55:49 PM EST] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Feb 20 03:00:00 EST 2013
[2/19/13 6:55:49 PM EST] INFO MediaScannerService Media library never scanned. Doing it now.
[2/19/13 6:55:49 PM EST] INFO MediaScannerService Starting to scan media library.
[2/19/13 6:55:49 PM EST] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Feb 19 19:00:49 EST 2013
[2/19/13 6:55:51 PM EST] INFO MediaScannerService Scanned media library with 0 entries.
[2/19/13 6:55:51 PM EST] INFO MediaScannerService Marking non-present files.
[2/19/13 6:55:51 PM EST] INFO MediaScannerService Marking non-present artists.
[2/19/13 6:55:51 PM EST] INFO MediaScannerService Marking non-present albums.
[2/19/13 6:55:51 PM EST] INFO MediaScannerService Completed media library scan.
[2/19/13 6:55:51 PM EST] INFO PlaylistService Starting playlist import.
[2/19/13 6:55:51 PM EST] INFO PlaylistService Completed playlist import.
[2/19/13 6:55:51 PM EST] INFO PlaylistService Starting playlist statistics update.
[2/19/13 6:55:51 PM EST] INFO PlaylistService Completed playlist statistics update.
[2/19/13 6:55:52 PM EST] INFO NetworkService Deleted port mapping for port 80
[2/19/13 7:00:49 PM EST] INFO PodcastService Starting scheduled Podcast refresh.
[2/19/13 7:00:49 PM EST] INFO PodcastService Completed scheduled Podcast refresh.
[2/19/13 7:02:02 PM EST] INFO VersionService Resolved local Subsonic version to: 4.7
[2/19/13 7:02:02 PM EST] INFO PlayerDao Created player 1.
[2/19/13 7:02:03 PM EST] INFO VersionService Resolved latest Subsonic final version to: 4.7
[2/19/13 7:02:03 PM EST] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta3
[2/19/13 7:06:24 PM EST] INFO SecurityService Created user jwa1882
[2/19/13 7:07:52 PM EST] INFO PlayerDao Created player 2.
jwa1882
Re: 0completely lost :(
Postby daneren2005 » Wed Feb 20, 2013 4:51 am
To get all of those options you need to log in as the admin. You can also give yourself all those same options while logged in as a admin so you don't need to log into the admin account in the future.
Postby jwa1882 » Thu Feb 21, 2013 1:47 am
gotcha....Thanks!!!!
jwa1882
