My subsonic.org address is not working....
Postby CasN » Wed Feb 20, 2013 7:48 pm
I am a bit lost here.
I have my subsonic site registered under cas.subsonic.org , this has been working perfectly all the time.
Now I moved from Win2003 to Clearos.
Re-installing worked out fine. The box has the same internal ip address as before under windows.
I use the same port (8081) as before.
So what's happening:
http://ipaddress:8081 works great
http://www.nuy.info:8081 works perfect
http://cas.subsonic.org fails to work, it is actually routed to the wrong internal address. (re-registering from within Subsonic worked fine)
Internally the server is on xx.xx.1.50 but the subsonic address ends up at xx.xx.1.60
Now the beauty, i have no forwarding to that address at all on my router :?:
Probably something simple but I fail to detect.
So who has a bright :idea: ?
CasN
Re: My subsonic.org address is not working....
Postby bushman4 » Wed Feb 20, 2013 8:20 pm
Works for me...
Does it only not work internally?
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby CasN » Wed Feb 20, 2013 10:00 pm
In my memory it worked before internally. Used the same address on the iphone/android app which worked from the inside too. Will check tomorrow again from the outside world and report back
CasN
Postby CasN » Thu Feb 21, 2013 5:33 pm
From the outside it is ok, so why would it have stopped working from the inside???
CasN
Postby bushman4 » Thu Feb 21, 2013 7:26 pm
Have you rebooted the router?
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby CasN » Thu Feb 21, 2013 9:23 pm
Yep, done that. If I ping it from the inside, I get a reply from 66.49.215.227.
That again seems to indicate that my router is given a wrong forward but that one is not defined........ :mrgreen:
CasN
Postby BKKKPewsey » Thu Feb 21, 2013 11:59 pm
CasN wrote:Yep, done that. If I ping it from the inside, I get a reply from 66.49.215.227.
You will do! that's the SS redirect server IP
