admin as password not working on first set up
Postby Jazzmanjon » Sun Feb 24, 2013 4:30 pm
I have just downloaded Subsonic hopefully as a replacement for Audiogalaxy! Unfortunately when I try to set it up I am faced with a "Wrong Username or password" message however I have not yet set any username or password. I try as instructed to enter "admin" as username and as the password but then get the Wrong Username or password message. I am using Windows 7 64 version bit on PC using Chrome as my browser and am using a DLink DIR 615 router. I have as suggested installed and downloaded the latest version of Java (64bit) . Help please. Thanks
Jazzmanjon
Re: admin as password not working on first set up
Postby Jazzmanjon » Sun Feb 24, 2013 4:35 pm
Sorry I've just read the how to ask for help post
Problem Description: (Admin as password not accepted by subsonic on first set up)
Troubleshooting Steps: (installed latest version of java)
Playback Application and version: (not known)
Subsonic Version: (N/A)
Server Version: (N/A)
Hardware Platform: (Windows, vers 7 64 bit)
Java Memory Limit: (N/A)
Problem Filename: ((N/A))
Output from ffmpeg -i: (N/A)
Last ten log file lines: (N/A)
Jazzmanjon
Postby BKKKPewsey » Sun Feb 24, 2013 5:49 pm
This does sometimes happen with a new install BUT SS does require 32bit Java so make sure you have that installed.
Postby Jazzmanjon » Sun Feb 24, 2013 6:27 pm
I have installed the 32bit version of java as well but I am still getting the error message
Jazzmanjon
Postby Jazzmanjon » Mon Feb 25, 2013 11:17 am
Hi I have now tried uninstalling Java and subsonic and then cleaning the registry with CC cleaner and then reintsalling the 32 bit version of java. However I still get the wrong username or password error when I try to start subsonic using admin as the user and password. Please any ideas?
Jazzmanjon
Postby BKKKPewsey » Mon Feb 25, 2013 1:32 pm
Do a clean install - delete the c:\subsonic folder then re-install.
When accessing the web interface for the first time SS should bring up a warning about the default password and telling you to change it.
Postby Jazzmanjon » Wed Feb 27, 2013 4:39 pm
Hurray Thanks very much. I deleted the install of subsonic and used ccleaner to get rid of any reference to it in the registry. I then downloaded a new copy and installed. It worked straight away! Thanks very much.
Think it probably was installing the 32 bit java even though I have a 64 bit version of Windows 7
Jazzmanjon
Users browsing this forum: No registered users and 41 guests
