Ubuntu Newbie
Ubuntu Newbie
Postby revolverfm » Sun Feb 24, 2013 5:58 pm
I really want to make the move away from Microsft and on to Ubuntu - however getting Subsonic up and running is proving to be quite a challenge, and as much as I use Subsonic I would actually go back to MS rather than lose it - but I would much rather figure out what I'm doing wrong!
First, I was able to get Subsonic installed on the latest version of Ubuntu Desktop (12.04.2 LTS), and I successfully launched Subsonic at localhost://4040. That's when everything started going downhill.
The first step I had trouble with was finding my music folders. I keep my files on external drives, and while Ubuntu recognizes and browses these drives without issue, I can't get Subsonic to locate them at all in the settings field. I've tried every path configuration that I could think of, and nothing is working.
From what I have seen, the path should be /media/(dive name)/music folder/. But I have not been able to get any variation of that to work.
Lastly, more important after I get everything working - I tried to follow the instructions in the documentation to alter the permissions and run Subsonic as a non-root user, but while I can edit the file, I can't save it. Is this just a permissions thing that I am overlooking?
Greatly appreciate any/all help!
revolverfm
Re: Ubuntu Newbie
Postby enix » Sun Feb 24, 2013 6:44 pm
Are you opening the config file as root? If you can't make changes I would bet not. Do you use a dm or console?
Sent from my SCH-I535 using Tapatalk 2
enix
Re: Ubuntu Newbie
Postby revolverfm » Sun Feb 24, 2013 6:49 pm
I am opening it as root, from within the terminal window.
revolverfm
Re: Ubuntu Newbie
Postby enix » Sun Feb 24, 2013 7:18 pm
When I'm in a console I type:
sudo nano /etc/default/subsonic
Enter my pass, make changes and save.
If you can't do that maybe something to do with groups?
Im not too sure really, amateur Linux user.
enix
Re: Ubuntu Newbie
Postby revolverfm » Sun Feb 24, 2013 8:29 pm
Amateur is right. I'll give that way a try.
Anyone have an idea as to my question about the path to the external drive?
revolverfm
Re: Ubuntu Newbie
Postby enix » Mon Feb 25, 2013 2:23 am
Are they NAS?
Only thing I can offer is browse to where your main folder is say: /home/johndoe/media/music in a console. the command pwd will print the working directory. Copy that to the settings spot in the browser. And scan media.
enix
Re: Ubuntu Newbie
Postby revolverfm » Mon Feb 25, 2013 1:40 pm
I'll give that a try. Thanks all - I appreciate the advice.
revolverfm
