IP Change
IP Change
Postby ufkal » Tue Feb 26, 2013 1:07 am
I changed my router, and so my ip settings have changed. Now, I can't figure out how to change my subsonic ip address.
I am running Open Media Vault.
I've tried to uninstall subsonic using the purge command, and then reinstall, but to no avail, its still trying to read the old ip address.....
For reference, I'm using a Netgear WNDR3400v2, and I have attempted to portforward, but that is another issue.
Oh, I can reach the subsonic site from the web using the webaddress I have. But I can not by IP or from Open Media Vault.
Thanks for help.
I appreciate it.
ufkal
Re: IP Change
Postby Geko » Tue Feb 26, 2013 4:18 pm
I have the same problem.
I had my subsonic configured to use my static ip when I first set up.
when I went to work i had to change my ip to dynamic to connect to work network .
when i got home i reset my ip back to static but now it has assigned my pc with a new ip.
Is there a way to revert back to the old ip (i wrote the old one down )
thanks
Geko
