Remote Acces Failure
Postby Skobone » Thu Feb 28, 2013 2:21 pm
Problem Description: Remote Hangs 404
Troubleshooting Steps: Increased Memory limit, Re installed server, reinstalled client, reconfigured modem... port forwarding... dmz.. nothing just hangs after while.
Playback Application and version: Standard Subsonic Web Interface, android client, minisub
Subsonic Version: 4.7 (build 3105)
Server Version: jetty-6.1.x, java 1.6.0_27, Linux (31.9 MB / 83.3 MB)
Hardware Platform: Ubuntu Server 12.04.2
Java Memory Limit: 512mb
Modem Cisco EPC3825. Server has reserved ip and it's in dmz area.
port forwarding is set for multiple services only subsonic is problem.
Tried x.subsonic.org andress instead of dyndns, problem remains.
Read everything could find and I have no idea.
Any suggestions?
Subsonic 4.7 (build 3105)
AMD Athlon 64 3500+, 1 cores
1Gb DDR2
2tb Disk Ext4
Skobone
Re: Remote Acces Failure
Postby gurutech » Thu Feb 28, 2013 6:53 pm
Version 4.7 should work with Java 1.7. I would try uninstalling 1.6 and installing 1.7, then test Subsonic.
gurutech
Postby Skobone » Sat Mar 02, 2013 11:53 am
"jetty-6.1.x, java 1.7.0_15, Linux (42.5 MB / 57.3 MB)"
No difference... Still hangs
I'm very confused because service doesn't hang. I think problem is in cisco:s modem because devices in lan work perfectly...
But on other hand
Does it matter that I use OpenJDK?
Should I use sun-JDK?
1Gb DDR2
2tb Disk Ext4
Skobone
Postby gurutech » Sat Mar 02, 2013 6:16 pm
If you have port forwarding, you don't need to have the server in the DMZ (unless it's there for other reasons).
Try putting it in the "internal" network (if nothing else requires DMZ) and forward the port from the router to the server.
gurutech
Postby Skobone » Mon Mar 04, 2013 4:14 am
Still no luck server is now behind NAT and portforwarding work for everything else but not for subsonic (ftp, ssh...)
I tried to register server to "x".subsonic.org again and it returns "Status: "x".subsonic.org returned HTTP error code 404 Not Found "
When restarted service by ssh returns "Status: Successfully registered web address. "
I'm not using UPnP or NAT-PMP port forwarding because it does't work and checking the box only returns error in log "upnp router not found"
Canyouseeme.org = "Success: I can see your service on xx.29.121.156 on port (4040)
Your ISP is not blocking port 4040"
What on earth could be wrong?
1Gb DDR2
2tb Disk Ext4
Skobone
Postby gurutech » Mon Mar 04, 2013 11:55 am
Try it with the uPNP turned on. I get the error from Subsonic saying it's not turned on also, but it still works.
gurutech
Postby Skobone » Mon Mar 04, 2013 2:34 pm
Says that no router found... Can't Forward adress to x.subsonic.org -> reboot service -> reboot router -> no difference
1Gb DDR2
2tb Disk Ext4
Skobone
Postby bushman4 » Mon Mar 04, 2013 4:29 pm
Let's test this methodically... try each of these and let me know where it fails. Once it fails you don't need to continue on:
1. On the subsonic server, open
http://127.0.0.1:YourHTTPPort/YourContextPath
Does Subsonic open? If you log on, does it work?
2. On the subsonic server, open
http://Your.Server.Internal.IPAddress:YourHTTPPort/YourContextPath
3. On a different computer on the same network open
4. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
http://Your.Server.External.IPAddress:YourHTTPPort/YourContextPath
5. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
http://YourCustomDomainName.subsonic.org
6. From the subsonic server computer, open
Does Subsonic open? If you log on, does it work? if not, what address (if any) are you redirected to?
7. From a different computer on the same network as the Subsonic Server, open
Let me know where it fails.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Skobone » Tue Mar 05, 2013 8:01 am
Some how router and server reboot fixed the problem this time... I have tried that before now over 20h running without any problems.
So far so good (still wondering the modem)
1Gb DDR2
2tb Disk Ext4
Skobone
Postby GJ51 » Tue Mar 05, 2013 8:36 am
Modems and routers do fail eventually due to heat which does tend to get generated by streaming. If either component is getting close to failure, streaming may just put enough stress on the weak device to cause it to fail once it gets up to critical temperature.
Sometimes you can verify and do a short term fix by opening the enclosiure and putting a fan on the suspect device. I've had good luck with my most recent Netgear WND3700 wireles router, but prior to this one I usually had to replace my router after about 2 years. Wireless routers are more suspicious than modems, but they can also fail - of course many gateway units from the isp are combination devices that include modem and router with WAP all in one device.
Postby Skobone » Tue Mar 05, 2013 2:40 pm
Modem/Router/WlanAP = Cisco EPC3825 "can deliver downstream data rates in excess of 440 Mbps and upstream data rates in excess of 120 Mbps" If I believe cisco and my contract is 100/2 so i think it's not too much but I have had problems with it before and I have been looking for EuroDOCSIS 3.0 bridge modem somewhere but no luck yet... NOT EVEN FROM ISP!
1Gb DDR2
2tb Disk Ext4
Skobone
Postby GJ51 » Tue Mar 05, 2013 5:36 pm
My current router was a replacement for a Cisco VPN router. I did get an extra few months out of it by cracking the case and drilling it full of holes to get some extra air flow.
All routers are pretty much a crap shoot. My current router is holding up very well, but I don't have any illusions that my experience with it is a reliable yardstick for the brand or model. More likely, I just got lucky and got a "good one". While in the process of installing the current router, I also hard wired most of the house with CAT 6 so there isn't much load on the wireless anymore. I think that may be the biggest factor in the performance of this current router. It mostly serves as a connector for our mobile devices and there is currently only one lightly used desktop accessing the network over wireless that only rarely is used for media streaming.
Keeping any router in a cool, well ventilated space should also help.
Postby Skobone » Wed Mar 20, 2013 4:11 am
All the problems are now gone after changing bridge cabel-modem and setting up dd-wrt asus router.
1Gb DDR2
2tb Disk Ext4
Skobone
