bug: cant delete playlist
Postby gson3001 » Mon Mar 04, 2013 9:38 am
Hi.
I cant find where to report bugs so ill try to post it here.
If i delete a playlist it will return the next time a rescan of the media folders is executed.
Bug or im am doing something wrong?
running subsonic 4.7 (build 3105)
gson3001
Re: bug: cant delete playlist
Postby BKKKPewsey » Mon Mar 04, 2013 12:57 pm
SS will import any playlists found in your scanned media folders so delete the the m3u/pls files or move them out from your SS scanned folders.
Postby gson3001 » Tue Mar 12, 2013 11:17 am
Yes i understand that this is the problem but shouldnt the delete command delete the playlist so i dont have to delete it?
gson3001
Postby bushman4 » Tue Mar 12, 2013 2:32 pm
Playlists have been imported into the database. Once they are imported, all of the old playlist files should be removed from the playlist directory, otherwise the next time you restart subsonic, the playlists will be reimported again, possibly overwriting the changes you might have made, or recreating a deleted playlist.
Changes made to playlists are NOT written back out to disc to files in the playlist directory.
The delete function is only deleting the new database-housed playlist.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
