Error when trying to clean database
Postby engmearn » Mon Mar 04, 2013 2:34 pm
Hi
This problem manifested itself last Thursday after no problems since 4.7 was originally released and installed on my PC. The first issue was that all my media folders disappeared with the error below. i managed to stop this error by moving the Music folders but, I now have 100 plus playlists that have no songs in i would imagine because the folders are in a different place. The more button dosn't work any more another java error. The clean up database option errors with a java error. And i can't Export the playlists either. I really don't want to loose the playlists if i can help it.
regards
Error
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Sun Microsystems Inc. 1.6.0_37
Server jetty-6.1.x
Memory Used 125 of 598 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; out of memory; nested exception is java.sql.SQLException: out of memory at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:106) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:607) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:641) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:670) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:678) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:710) at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83) at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120) at net.sourceforge.subsonic.dao.MediaFileDao.getMediaFile(MediaFileDao.java:58) at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:103) at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:145) at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61) at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220) at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:166) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:712) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:139) at org.mortbay.jetty.Server.handle(Server.java:313) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:506) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:830) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:381) at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:396) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:442) Caused by: java.sql.SQLException: out of memory at org.hsqldb.jdbc.Util.throwError(Unknown Source) at org.hsqldb.jdbc.jdbcPreparedStatement.executeQuery(Unknown Source) at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:648) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:591) ... 65 more
Problem Description: music folders disappeared in subsonic even though nothing was changed on the server.
Troubleshooting Steps: reinstalled subsonic removed java and replaced it again. Carried out a system restore of my windows operating system to a date before the first issue
Playback Application and version: firefox / Internet Explorer.
Subsonic Version: Version 4.7 (build 3105) – 12 septembre 2012
Server Version: jetty-6.1.x, java 1.6.0_37, Windows 7 (144.4 MB / 598.9 MB)
Hardware Platform: Windows 7 X64
Java Memory Limit: no
Problem Filename: no
Output from ffmpeg -i: no
Last ten log file lines:
engmearn
Re: Error when trying to clean database
Postby bushman4 » Mon Mar 04, 2013 4:22 pm
Allocate more memory to the Subsonic process. Although that may be an erroneous error message, given that it says you are using less that 30% of what you have allocated to Subsonic.
But if I see an "Out of Memory" error, the first thing I would try is allocating more memory...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
