subsonic would not run. What do you think I am missing?
Postby alh » Sun Jun 01, 2008 5:05 am
Got tomcat running on my linux box as you can tell from the message below:
If you're seeing this page via a web browser, it means you've setup Tomcat successfully. Congratulations!
As you may have guessed by now, this is the default Tomcat home page. It can be found on the local filesystem at:
$CATALINA_HOME/webapps/ROOT/index.jsp
when I try to run subsonic this what I see on the web side
HTTP Status 404 - /subsonic/
type Status report
message /subsonic/
description The requested resource (/subsonic/) is not available.
Apache Tomcat/5.5
I installed the war file and put everything where it should be but I get this message in the log:
May 31, 2008 9:41:49 PM org.apache.catalina.startup.Catalina stopServer
SEVERE: Catalina.stop:
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:520)
at java.net.Socket.connect(Socket.java:470)
at java.net.Socket.<init>(Socket.java:367)
at java.net.Socket.<init>(Socket.java:180)
at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:394)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:343)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:434)
May 31, 2008 9:41:52 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/lib/jvm/java-1.5.0-sun-1.5.0.14/jre/lib/i386/client:/usr/lib/jvm/java-1.5.0-sun-1.5.0.14/jre/lib/i386:/usr/lib/jvm/java-1.5.0-sun-1.5.0.14/jre/../lib/i386
May 31, 2008 9:41:52 PM org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8180
May 31, 2008 9:41:52 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2882 ms
May 31, 2008 9:41:52 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
May 31, 2008 9:41:52 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5
May 31, 2008 9:41:53 PM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
May 31, 2008 9:41:56 PM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8180
May 31, 2008 9:41:56 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
May 31, 2008 9:41:56 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/84 config=null
May 31, 2008 9:41:57 PM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
May 31, 2008 9:41:57 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 4755 ms
May 31, 2008 9:42:29 PM org.apache.catalina.startup.Catalina stopServer
May 31, 2008 9:42:33 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
May 31, 2008 9:42:34 PM org.apache.coyote.http11.Http11BaseProtocol init
May 31, 2008 9:42:34 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 5529 ms
May 31, 2008 9:42:35 PM org.apache.catalina.core.StandardService start
May 31, 2008 9:42:35 PM org.apache.catalina.core.StandardEngine start
May 31, 2008 9:42:35 PM org.apache.catalina.core.StandardHost start
May 31, 2008 9:42:42 PM org.apache.coyote.http11.Http11BaseProtocol start
May 31, 2008 9:42:42 PM org.apache.jk.common.ChannelSocket init
May 31, 2008 9:42:42 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=1/88 config=null
May 31, 2008 9:42:43 PM org.apache.catalina.storeconfig.StoreLoader load
May 31, 2008 9:42:43 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 8781 ms
May 31, 2008 9:43:16 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
May 31, 2008 9:43:17 PM org.apache.coyote.http11.Http11BaseProtocol init
May 31, 2008 9:43:17 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 4342 ms
May 31, 2008 9:43:17 PM org.apache.catalina.core.StandardService start
May 31, 2008 9:43:17 PM org.apache.catalina.core.StandardEngine start
May 31, 2008 9:43:17 PM org.apache.catalina.core.StandardHost start
May 31, 2008 9:43:25 PM org.apache.coyote.http11.Http11BaseProtocol start
May 31, 2008 9:43:27 PM org.apache.jk.common.ChannelSocket init
May 31, 2008 9:43:27 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/97 config=null
May 31, 2008 9:43:28 PM org.apache.catalina.storeconfig.StoreLoader load
May 31, 2008 9:43:28 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 11063 ms
May 31, 2008 9:53:27 PM org.apache.coyote.http11.Http11BaseProtocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8180
May 31, 2008 9:53:28 PM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
May 31, 2008 9:53:29 PM org.apache.coyote.http11.Http11BaseProtocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8180
May 31, 2008 9:53:29 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: Failed shutdown of Apache Portable Runtime
May 31, 2008 9:55:24 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
May 31, 2008 9:55:24 PM org.apache.coyote.http11.Http11BaseProtocol init
May 31, 2008 9:55:24 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2514 ms
May 31, 2008 9:55:25 PM org.apache.catalina.core.StandardService start
May 31, 2008 9:55:25 PM org.apache.catalina.core.StandardEngine start
May 31, 2008 9:55:25 PM org.apache.catalina.core.StandardHost start
May 31, 2008 9:55:30 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive subsonic.war
May 31, 2008 9:55:32 PM org.apache.commons.modeler.Registry registerComponent
SEVERE: Error registering Catalina:type=Valve,name=StandardContextValve,path=/subsonic,host=localhost
javax.management.MBeanException: Cannot instantiate ModelMBean of class org.apache.commons.modeler.BaseModelMBean
at org.apache.commons.modeler.ManagedBean.createMBean(ManagedBean.java:430)
at org.apache.commons.modeler.Registry.registerComponent(Registry.java:862)
at org.apache.catalina.core.StandardPipeline.registerValve(StandardPipeline.java:301)
at org.apache.catalina.core.StandardPipeline.start(StandardPipeline.java:233)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4135)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:759)
at org.apache.catalina.core.ContainerBase.access$0(ContainerBase.java:743)
at org.apache.catalina.core.ContainerBase$PrivilegedAddChild.run(ContainerBase.java:143)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:737)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1122)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:310)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1021)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:718)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442)
at org.apache.catalina.core.StandardService.start(StandardService.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
Caused by: java.security.AccessControlException: access denied (java.io.FilePermission /var/lib/tomcat5.5/webapps/subsonic/WEB-INF/classes/logging.properties read)
at java.security.AccessControlContext.checkPermission(AccessControlContext.java:264)
at java.security.AccessController.checkPermission(AccessController.java:427)
at java.lang.SecurityManager.checkPermission(SecurityManager.java:532)
at java.lang.SecurityManager.checkRead(SecurityManager.java:871)
at java.io.File.exists(File.java:700)
at org.apache.naming.resources.FileDirContext.file(FileDirContext.java:827)
at org.apache.naming.resources.FileDirContext.lookup(FileDirContext.java:210)
at org.apache.naming.resources.ProxyDirContext.lookup(ProxyDirContext.java:293)
at org.apache.catalina.loader.WebappClassLoader.findResourceInternal(WebappClassLoader.java:1887)
at org.apache.catalina.loader.WebappClassLoader.findResource(WebappClassLoader.java:929)
at org.apache.juli.ClassLoaderLogManager.readConfiguration(ClassLoaderLogManager.java:298)
at org.apache.juli.ClassLoaderLogManager$2.run(ClassLoaderLogManager.java:272)
at org.apache.juli.ClassLoaderLogManager.getClassLoaderInfo(ClassLoaderLogManager.java:269)
at org.apache.juli.ClassLoaderLogManager.getLogger(ClassLoaderLogManager.java:174)
at java.util.logging.Logger.getLogger(Logger.java:255)
at com.sun.jmx.trace.TraceManager.getLogger(TraceManager.java:184)
at com.sun.jmx.trace.TraceManager.isSelected(TraceManager.java:197)
at com.sun.jmx.trace.Trace.isSelected(Trace.java:84)
at javax.management.modelmbean.ModelMBeanInfoSupport.tracing(ModelMBeanInfoSupport.java:966)
at javax.management.modelmbean.ModelMBeanInfoSupport.<init>(ModelMBeanInfoSupport.java:319)
at javax.management.modelmbean.ModelMBeanInfoSupport.<init>(ModelMBeanInfoSupport.java:260)
at org.apache.commons.modeler.BaseModelMBean.createDefaultModelMBeanInfo(BaseModelMBean.java:1366)
at org.apache.commons.modeler.BaseModelMBean.<init>(BaseModelMBean.java:163)
at sun.reflect.GeneratedConstructorAccessor6.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
at org.apache.commons.modeler.ManagedBean.createMBean(ManagedBean.java:423)
... 29 more
May 31, 2008 9:55:32 PM org.apache.catalina.core.StandardPipeline registerValve
INFO: Can't register valve org.apache.catalina.core.StandardContextValve[/subsonic]
... 29 more
May 31, 2008 9:55:33 PM org.apache.commons.modeler.Registry registerComponent
SEVERE: Error registering Catalina:type=Manager,path=/subsonic,host=localhost
at org.apache.catalina.session.ManagerBase.init(ManagerBase.java:713)
at org.apache.catalina.session.StandardManager.start(StandardManager.java:618)
at org.apache.catalina.core.ContainerBase.setManager(ContainerBase.java:431)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4155)
... 30 more
May 31, 2008 9:55:36 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/subsonic] startup failed due to previous errors
May 31, 2008 9:55:36 PM org.apache.commons.modeler.Registry unregisterComponent
SEVERE: Error unregistering mbean
at com.sun.jmx.trace.TraceManager.getLogger(TraceManager.java:166)
at com.sun.jmx.mbeanserver.RepositorySupport.isTraceOn(RepositorySupport.java:87)
at com.sun.jmx.mbeanserver.RepositorySupport.contains(RepositorySupport.java:472)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.isRegistered(DefaultMBeanServerInterceptor.java:556)
at com.sun.jmx.mbeanserver.JmxMBeanServer.isRegistered(JmxMBeanServer.java:619)
at org.apache.commons.modeler.Registry.unregisterComponent(Registry.java:642)
at org.apache.catalina.session.ManagerBase.destroy(ManagerBase.java:691)
at org.apache.catalina.session.StandardManager.stop(StandardManager.java:692)
at org.apache.catalina.core.StandardContext.stop(StandardContext.java:4358)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4241)
java.security.AccessControlException: access denied (java.io.FilePermission /WEB-INF/classes/logging.properties read)
at org.apache.catalina.core.StandardContext.resourcesStop(StandardContext.java:3900)
at org.apache.catalina.core.StandardContext.stop(StandardContext.java:4381)
May 31, 2008 9:55:37 PM org.apache.catalina.loader.WebappClassLoader findResourceInternal
INFO: Illegal access: this web application instance has been stopped already. Could not load logging.properties. The eventual following stack trace is caused by an error thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access, and has no functional impact.
May 31, 2008 9:55:37 PM org.apache.coyote.http11.Http11BaseProtocol start
May 31, 2008 9:55:38 PM org.apache.jk.common.ChannelSocket init
May 31, 2008 9:55:38 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/92 config=null
May 31, 2008 9:55:38 PM org.apache.catalina.storeconfig.StoreLoader load
May 31, 2008 9:55:38 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 14116 ms
May 31, 2008 10:00:24 PM org.apache.coyote.http11.Http11BaseProtocol pause
May 31, 2008 10:00:25 PM org.apache.catalina.core.StandardService stop
May 31, 2008 10:00:25 PM org.apache.coyote.http11.Http11BaseProtocol destroy
May 31, 2008 10:00:25 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
May 31, 2008 10:00:57 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
May 31, 2008 10:00:57 PM org.apache.coyote.http11.Http11BaseProtocol init
May 31, 2008 10:00:57 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2400 ms
May 31, 2008 10:00:58 PM org.apache.catalina.core.StandardService start
May 31, 2008 10:00:58 PM org.apache.catalina.core.StandardEngine start
May 31, 2008 10:00:58 PM org.apache.catalina.core.StandardHost start
May 31, 2008 10:01:02 PM org.apache.catalina.startup.HostConfig deployWAR
May 31, 2008 10:01:02 PM org.apache.commons.modeler.Registry registerComponent
... 29 more
May 31, 2008 10:01:02 PM org.apache.catalina.core.StandardPipeline registerValve
... 29 more
May 31, 2008 10:01:03 PM org.apache.commons.modeler.Registry registerComponent
... 30 more
May 31, 2008 10:01:05 PM org.apache.catalina.core.StandardContext start
May 31, 2008 10:01:05 PM org.apache.commons.modeler.Registry unregisterComponent
May 31, 2008 10:01:06 PM org.apache.catalina.loader.WebappClassLoader findResourceInternal
May 31, 2008 10:01:06 PM org.apache.coyote.http11.Http11BaseProtocol start
May 31, 2008 10:01:07 PM org.apache.jk.common.ChannelSocket init
May 31, 2008 10:01:07 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/98 config=null
May 31, 2008 10:01:07 PM org.apache.catalina.storeconfig.StoreLoader load
May 31, 2008 10:01:08 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 10469 ms
May 31, 2008 10:21:03 PM org.apache.coyote.http11.Http11BaseProtocol pause
May 31, 2008 10:21:04 PM org.apache.catalina.core.StandardService stop
May 31, 2008 10:21:04 PM org.apache.coyote.http11.Http11BaseProtocol destroy
May 31, 2008 10:21:04 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
May 31, 2008 10:21:13 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
May 31, 2008 10:21:13 PM org.apache.coyote.http11.Http11BaseProtocol init
May 31, 2008 10:21:13 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2421 ms
May 31, 2008 10:21:14 PM org.apache.catalina.core.StandardService start
May 31, 2008 10:21:14 PM org.apache.catalina.core.StandardEngine start
May 31, 2008 10:21:14 PM org.apache.catalina.core.StandardHost start
May 31, 2008 10:21:18 PM org.apache.catalina.startup.HostConfig deployWAR
May 31, 2008 10:21:19 PM org.apache.commons.modeler.Registry registerComponent
alh
Postby jigsaw » Mon Jun 02, 2008 11:30 pm
You could check two things:
A quick google search indicated that the error
may suggest some other service is occupying the requested port. However my Tomcat issues the error message "java.net.BindException: Address already in use:8080" if that happens.
1) Check that no other services is already listening on port 8180 which it seems you have configured your tomcat to listen on.
Edit: On second thought it can't be a port issue as you are getting the welcome-page ok...
Otherwise it may be this error
Usually tomcat is installed in /usr/local/tomcat, but it seems from the error that you have it installed in /var/lib/tomcat5.5
2) Check that you are starting tomcat as the tomcat user and that the file permissions in TOMCAT_HOME are correct (should be owned by tomcat)
jigsaw
Postby sindre_mehus » Tue Jun 03, 2008 6:39 am
Please take a look at this post.
Hope this helps,
Users browsing this forum: No registered users and 77 guests
