mysql setup?
mysql setup?
Postby mrdrew » Sat Mar 09, 2013 4:39 am
I'd like to setup subsonic to use an external mysql database to (hopefully?) speed it up.
I'm currently running subsonic server, donation/registered, on unRaid NAS. It's a slackware based reiserfs NAS behind a firewall. I've opened a port in the firewall, and can use the web GUI no problemo.
I didn't see any options for an external database anywhere in the user, or admin account web GUI. Any ideas? Thank you!
drew
Version 4.7 (build 3105) – September 11, 2012
Server jetty-6.1.x, java 1.7.0_02, Linux (60.8 MB / 96.7 MB)
mrdrew
Re: mysql setup?
Postby hakko » Sat Mar 09, 2013 7:36 am
There's no option to use an external database in Subsonic 4.x. I haven't seen anyone tweak it to run on MySQL. Personally, I run a highly modified Subsonic server with a PostgreSQL backend, but I had to write a lot of code to make that work.
MusicCabinet developer
hakko
Re: mysql setup?
Postby mrdrew » Sat Mar 09, 2013 8:02 am
Out of curiosity, do you know what kind of database it natively uses?
mrdrew
Re: mysql setup?
Postby hakko » Sat Mar 09, 2013 9:50 am
Last time I checked it was hsqldb 1.8.0.7 released 2006-09-27 (http://hsqldb.org/doc/1.8/changelist_1_8_0.txt). Not the exact solution I would recommend.
hakko
Re: mysql setup?
Postby tsquillario » Sun Dec 22, 2013 8:21 pm
hakko wrote:There's no option to use an external database in Subsonic 4.x. I haven't seen anyone tweak it to run on MySQL. Personally, I run a highly modified Subsonic server with a PostgreSQL backend, but I had to write a lot of code to make that work.
Does MusicCabinet run 100% off of Postgres? I guess I'm not really understanding the add-on part. Does Subsonic still need to run using it's built-in database?
Jamstash Developer
Chrome App - https://chrome.google.com/webstore/detail/jccdpflnecheidefpofmlblgebobbloc
Beta Site - http://beta.jamstash.com
GitHub Project - https://github.com/tsquillario/Jamstash
tsquillario
Postby daneren2005 » Sun Dec 22, 2013 9:08 pm
Yes and yes. Hakko only wrote a PostgreSQL back end, and main Subsonic still only works with its built in db.
Sent from my HTC One X using Tapatalk
