Windows auto-start
Windows auto-start
Postby mastweb » Sun Mar 10, 2013 5:53 pm
I just installed SubSonic. I won't be using it so often so I would like to disable the auto-start when I boot Windows and activate my server only when I want. I tried to disable the SubSonic Service in msconfig, but I could not SubSonic at all. Is there a way to to this? I don't like having softwares running in the back of my computer when I'm not using them...
mastweb
Re: Windows auto-start
Postby alphawave7 » Sun Mar 10, 2013 6:28 pm
Use the systray Control Panel to stop a running instance...the 'manual start' of the service should work, reboot and check. :)
Postby mastweb » Mon Mar 11, 2013 2:48 am
Well wasn't that easy!!! haha
I didn't think it would work since it was written "Not running. Auto-start.", but yes the service in not running in the background anymore.
mastweb
Postby mastweb » Wed Apr 10, 2013 9:37 pm
Sadly, it's does not work at long term. I didm't re-activate it, but the service is still running at Windows startup.
Any other ideas?
mastweb
Postby bushman4 » Fri Apr 12, 2013 1:28 pm
Go into the services control panel and change the "subsonic" service to "Manual" instead of "Automatic."
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby mastweb » Sat Apr 13, 2013 3:49 am
The "Auto-start" disappeared in the Subsonic control panel! Looks good. I'll check when I reboot for a few days.
mastweb
