how to order tracks by album?
Postby nitche » Mon Mar 11, 2013 2:52 pm
hello,
i installed subsonic on my server and imported a lot of music. i have one folder by artist, and no sub-folders for albums (it's a mass importation from my player at home).
now, i would like to order my tracks by album name, but i don't see the option. is it possible? or do i have to create ALL subfolders for albums to have a clean display?
nitche
Re: how to order tracks by album?
Postby hakko » Mon Mar 11, 2013 2:56 pm
Do you want your media collection displayed completely by tags or completely by folder structure, or something in between?
MusicCabinet developer
hakko
Postby nitche » Mon Mar 11, 2013 3:00 pm
the best would be by tags, like in a player like rhythm'box or winamp where i can browse by artist or by albums :D
nitche
Postby hakko » Mon Mar 11, 2013 3:10 pm
Then you might be interested in this: http://dilerium.se/musiccabinet. There are pros and cons, so what server you'll want completely depends on your personal requirements.
hakko
Postby nitche » Mon Mar 11, 2013 3:23 pm
this add-on sounds great!
but i don't know how to install it :(
i'm using an ubuntu server. i installed postgre, but i don't know what to do with this step:
"Run the Windows installer, use the stand-alone version or the Tomcat war."
do i have to run a java command or something like that?
nitche
Postby hakko » Mon Mar 11, 2013 4:34 pm
It depends on how used you are to working with the terminal. If you download the stand-alone zip file, it contains a file named subsonic.sh which basically starts your server (if you have Java 7 installed and on your path).
You'll have to play around a bit with it, set executable rights on it etc. I ran across a write-up on the internet: http://virtuallyhyper.com/2013/02/insta ... -subsonic/
But there's no one-click-installer, so it's kind of on your own risk, if it seems worth it.
hakko
Postby nitche » Tue Mar 12, 2013 3:17 pm
hello,
i made the installation using this method: viewtopic.php?f=8&t=10220&p=52928&hilit=install+musiccabinet#p52928
and upgrading java from 6 to 7 this way: http://unix.stackexchange.com/questions ... ux-mint-13
now, it works great :D
thank you, subsonic is a wonderfull application, i will use it and talk about it a lot !! :wink:
nitche
Users browsing this forum: No registered users and 73 guests
