Can't connect to my server via 3G/HSPA+!
Postby jordstar » Mon Mar 11, 2013 6:42 pm
Problem Description: My phone (LG Google Nexus 4) will not connect to my personal Subsonic server over 3G/HSPA+, though it will locate and connect to the Subsonic demo server over 3G/HSPA+, and it will locate and connect to my personal Subsonic server over my home wi-fi.
Troubleshooting Steps: I've set up port forwarding for ports 80 and 4040 on my server, and run through the instructions at viewtopic.php?f=6&t=4867
Playback Application and version: Subsonic for Android
Subsonic Version: 4.7 (build 3106) – September 12, 2012
Server Version: jetty-6.1.x, java 1.7.0_11, Windows 7 (49.6 MB / 74.0 MB)
Hardware Platform: Windows 7 64-bit
Java Memory Limit: 150 MB
Problem Filename: n/a
Output from ffmpeg -i: n/a
Last ten log file lines:
[3/11/13 12:09:09 PM EDT]   INFO   DaoHelper   Checking database schema.
[3/11/13 12:09:21 PM EDT]   INFO   DaoHelper   Done checking database schema.
[3/11/13 12:09:22 PM EDT]   INFO   VersionService   Resolved local Subsonic version to: 4.7
[3/11/13 12:09:31 PM EDT]   INFO   PlayerDao   Deleted 1 player(s) that haven't been used after Thu Jan 10 12:09:31 EST 2013
[3/11/13 12:09:32 PM EDT]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Mar 12 03:00:00 EDT 2013
[3/11/13 12:09:32 PM EDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Mon Mar 11 12:14:32 EDT 2013
[3/11/13 12:09:34 PM EDT]   WARN   SettingsService   Failed to validate license.
[3/11/13 12:09:34 PM EDT]   WARN   NetworkService   Failed to register web address.
[3/11/13 12:09:35 PM EDT]   INFO   NetworkService   Deleted port mapping for port 4040
[3/11/13 12:09:41 PM EDT]   INFO   PlayerDao   Created player 5.
[3/11/13 12:14:32 PM EDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[3/11/13 12:14:32 PM EDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[3/11/13 2:27:32 PM EDT]   INFO   VersionService   Resolved latest Subsonic final version to: 4.7
[3/11/13 2:27:32 PM EDT]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.7.beta3
jordstar
Re: Can't connect to my server via 3G/HSPA+!
Postby bushman4 » Mon Mar 11, 2013 6:46 pm
The redirect service was down until very recently.
Restart your Subsonic server, or at least go to the network page and "save" the custom domain name and it should register correctly.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby jordstar » Wed Mar 13, 2013 2:42 pm
bushman4 wrote:The redirect service was down until very recently.
Glenn
Sorry to say-- I recognized Subsonic's servers were temporarily down as even their website was inaccessible for a few hours.
I waited until it came back up and tried a server restart plus re-saving my custom domain name.
That did nothing and the problem persists. I get "A network error occurred. Please check the server address or try again later."
jordstar
Postby bushman4 » Wed Mar 13, 2013 2:52 pm
If you just did it recently, the redirect service is down again.
My quick check is always to fire up http://demo.subsonic.org. If that doesn't work, it is probably the redirect service.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby jordstar » Wed Mar 13, 2013 4:57 pm
bushman4 wrote:If you just did it recently, the redirect service is down again.
Glenn
Thanks Glenn. That is my quick check too, but it's not inidicative of anything.
I check my connection to http:\\demo.subsonic.org via my phone's 3G/HSPA+ every single time before attempting to connect to my own named server.
And every single time, I receive the message "Connection is OK" from the Subsonic demo server within two seconds; then when immediately afterward attempting to connect to my own server in the same manner, I receive the message "A network error occurred. Retrying X of 4" four times, then "A network error occurred. Please check the server address or try again later."
Is the redirect server continually down (except for the demo server)? This isn't just a recent problem in light of the server issues you demonstrated by your server message charts in the other thread-- I have literally never been able to connect to my personal server via 3G/HSPA+ since I subscribed to the Subsonic service.
jordstar
Postby bushman4 » Thu Mar 14, 2013 12:53 pm
Then that is not your problem...
Try each of these and let me know where it fails. Once it fails you don't need to continue on:
1. On the subsonic server, open
http://127.0.0.1:YourHTTPPort/YourContextPath
Does Subsonic open? If you log on, does it work?
2. On the subsonic server, open
http://Your.Server.Internal.IPAddress:YourHTTPPort/YourContextPath
3. On a different computer on the same network open
4. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
http://Your.Server.External.IPAddress:YourHTTPPort/YourContextPath
5. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
http://YourCustomDomainName.subsonic.org
6. From the subsonic server computer, open
Does Subsonic open? If you log on, does it work? if not, what address (if any) are you redirected to?
7. From a different computer on the same network as the Subsonic Server, open
Let me know where it fails.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby jordstar » Sun Mar 17, 2013 6:10 pm
Thanks Glenn. I tried every step since I figured it might be more illustrative. Everything works except when I try to connect from outside the firewall in #4 and #5.
I'm going through a LinkSys E3000 and I had figured port 4040 was forwarded properly, but obviously not... if you can tell me what I've been doing wrong, I'd really appreciate the help.
bushman4 wrote:Then that is not your problem...
Subsonic opens and works.
bushman4 wrote:2. On the subsonic server, open
bushman4 wrote:3. On a different computer on the same network open
Subsonic opens and works. (used Chrome from Nexus 4 as test)
bushman4 wrote:4. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
(used Chrome from Nexus 4 as test) Chrome returned its standard "This web page is not available" 404 message.
bushman4 wrote:5. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
bushman4 wrote:6. From the subsonic server computer, open
bushman4 wrote: 7. From a different computer on the same network as the Subsonic Server, open
Glenn
jordstar
Postby bushman4 » Mon Mar 18, 2013 2:39 pm
http://portforward.com/english/routers/ ... bsonic.htm
Ignore the part where it tells you to also forward port 80... if you have subsonic set to port 4040 and are not using SSL, all you need to forward is port 4040.
Once you are done the test at http://www.canyouseeme.org/ should work for the ports you have chosen.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby jordstar » Tue Mar 19, 2013 1:22 am
Thanks Glenn! I deleted the instructions to forward to port 80 and retried successfully to connect to Subsonic in mobile Chrome using both the external IP address and my personal server address.
I can also connect through the app.
Thanks again for your help and attention!!!!
bushman4 wrote:http://portforward.com/english/routers/port_forwarding/Cisco/Linksys-E3000/Subsonic.htm
Glenn
jordstar
