Lost Admin Account
Lost Admin Account
Postby AngryMoose » Fri Jun 13, 2008 10:30 am
Is there a way to force admin privileges back onto an account, I'm not sure how I've done it but it looks like I don't have any account with admin anymore.
AngryMoose
Postby sindre_mehus » Sat Jun 14, 2008 12:47 pm
The "admin" user can't be deleted or modified, so if you remember its password you can use that.
Otherwise you have to either wipe out the subsonic database or reset the password by manually connecting to the database. I can provide the details if you're interested.
Postby AngryMoose » Tue Jun 17, 2008 10:30 am
The admin account is what I currently log in with it just seems to not have the admin options on it anymore. Resetting the database is fine by me since I'm really the only person using it.
AngryMoose
Postby sindre_mehus » Tue Jun 17, 2008 11:14 am
To reset the database, do the following:
1. Stop subsonic.
2. Rename SUBSONIC_HOME/db to SUBSONIC_HOME/db.old
3. Start subsonic.
Postby msdomino » Fri Aug 22, 2008 8:42 pm
i've done this, but still i am greeted with the wrong username or password, i know i've buggered something up here.
tried uninstalling and reinstalling (including regclean & temp removal) but i can't seem to get logged in.
ok, finally found the user id, thanks for the tip!
msdomino
