How to prevent access via Android/Iphone client.
Postby perochiri » Thu Mar 21, 2013 1:05 pm
Hi all,
I hope I am in the right section. Otherwise please feel free to move this topic.
I am running subsonic on an ubuntu10 linux server. I denied downloading my music on the webinterface but I am still struggling with the mobile apps.
My question is:
Is it possible to block these apps?
or is it possible to trancscode these files also to a minimum bitrate?
Cheers,
Pero
perochiri
Re: How to prevent access via Android/Iphone client.
Postby bushman4 » Thu Mar 21, 2013 3:15 pm
perochiri wrote:Is it possible to block these apps?
No.
perochiri wrote:is it possible to trancscode these files also to a minimum bitrate?
There is a maximum bitrate setting per user. There is also a maximum bitrate setting for each player.
hth,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby perochiri » Thu Mar 21, 2013 3:27 pm
Thank you very much bushman4 for you answer.
So the bitrate setting is globally (webinterface and app)?
I checked the (cached) download file and it has the full quality (360kbit instead of 64kbits).
Thank you again.
perochiri
Postby bushman4 » Thu Mar 21, 2013 3:31 pm
It should be...
Did you try limiting the bitrate on the player?
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Users browsing this forum: No registered users and 73 guests
