Stream over non-wifi
Postby jlm86 » Sun Mar 24, 2013 3:57 pm
I used to be able to stream my music over non-wifi , just basic phone connection...
Now it does not work anymore?
I do have unchecked "...stream over wifi only..."
any ideas?
Also, sometimes it will ONLY stream over my home network..?
thanks
jlm86
Re: Stream over non-wifi
Postby bushman4 » Tue Mar 26, 2013 3:10 pm
Let's test this methodically... try each of these and let me know where it fails. Once it fails you don't need to continue on:
1. On the subsonic server, open
http://127.0.0.1:YourHTTPPort/YourContextPath
Does Subsonic open? If you log on, does it work?
2. On the subsonic server, open
http://Your.Server.Internal.IPAddress:YourHTTPPort/YourContextPath
3. On a different computer on the same network open
4. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
http://Your.Server.External.IPAddress:YourHTTPPort/YourContextPath
5. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
http://YourCustomDomainName.subsonic.org
6. From the subsonic server computer, open
Does Subsonic open? If you log on, does it work? if not, what address (if any) are you redirected to?
7. From a different computer on the same network as the Subsonic Server, open
Let us know where it fails.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
