Error in Register Adress
Postby jcnaweb » Tue Mar 26, 2013 11:35 am
I´m using Subsonic above 4 months, and sundelly, I can´t connect in my "easy to remeber-adress"
Strange, was working very good until 3 days ago. I don´t change anything!
The message:
Status: Successfully forwarding port 4040.
Access your server over the Internet using an easy-to-remember address.
http://.subsonic.org
Status: .subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
jcnaweb
Re: Error in Register Adress
Postby bushman4 » Tue Mar 26, 2013 2:01 pm
Check to make sure that you port mapping on your firewall still points to the Ip address of your subsonic server, and that you are not being blocked by a firewall on the Subsonic server.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
