Personal server address resolving to VirtualBox IP
Postby wingo395 » Tue Mar 26, 2013 8:22 pm
Hi all,
I have a Windows 8 guest in a Virtual Box on a Windows 7 x64 host.
My problem is that when I connect via my personal server address, http:/xxxxx.subsonic.org, it resolves to the Ethernet adapter VirtualBox Host-Only Network IP address. Even without VirtualBox running on the host system, the IP address apparently resolves to the actual IP that Subsonic is running on, which works when I'm connected to my WiFi, but once I leave the house and my phone goes to the data network, it can't resolve that VirtualBox IP address. I end up having to connect by entering the actual IP, 192.168.5.106:8080.
How can I make xxxxx.subsonic.org "forget" my VirtualBox address and resolve to the actual Subsonic server's IP? At one point, I did find 192.168.56.1 (VirtualBox IP) in the subsonic.script file, but when I later went back to try to remove it, it was gone. Yet, subsonic.org still tries to resolve to the VirtualBox server address.
wingo395
Re: Personal server address resolving to VirtualBox IP
Postby wingo395 » Tue Mar 26, 2013 8:41 pm
Well, I managed to fix it.. nevermind..
I disabled the VirtualBox "adapter" and then restarted the server and connected and the correct IP was resolved.
Enabled the VB adapter and all was find after that.
wingo395
