Cable modem blocking ports?
Postby jlm86 » Sun Mar 31, 2013 12:53 pm
spent quite a few hours trying to figure this
out.
Could my cable modem be blocking my
Ports?
after I cable replaced the modem subsonic
Stopped working..
jlm86
Re: Cable modem blocking ports?
Postby gurutech » Mon Apr 01, 2013 3:58 am
With a new cable modem, you received a new IP address. You will need to check your external IP address to ensure your domain name (if using a dynamic DNS provider) is set to the correct IP address, or just use your external IP address.
gurutech
Postby jlm86 » Mon Apr 01, 2013 8:46 am
Fixed!!
The cable modem was also a router, unknown to me.....
I had them remove it and replaced with plain cable modem.....
done....
thanks
jlm86
Users browsing this forum: No registered users and 66 guests
