Jukebox mode doesnt work
Postby haribos » Fri Apr 12, 2013 8:55 am
I've created a new user called 'music' with permission to use jukebox mode and nothing else. When I'm logging in with this user I can browse trough my music collection but can't adding music to the queue list. What I'm doing wrong here? Because the required permissions are granted.
And for every device wich one connects to this server there will be a new 'player' with no jukebox mode enabled, how can I force this by default? Because i want to use this server wich everyone can connect with user 'music' and play music on this server.
haribos
Re: Jukebox mode doesnt work
Postby BKKKPewsey » Fri Apr 12, 2013 10:30 am
If I re-write the permissions to :-
User is allowed to play files AND
User is allowed to play files in jukebox mode
You will see why it doesn't work - you have to tick the first box to allow the second option (jukebox) to function.
Postby haribos » Fri Apr 12, 2013 10:45 am
BKKKPewsey wrote:If I re-write the permissions to :-
But then the user can play music on it's own device? The music must only be played on the server.
haribos
Postby bushman4 » Fri Apr 12, 2013 12:45 pm
Not possible. Don't give the password to anyone you don't trust to only use Jukebox mode.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby haribos » Fri Apr 12, 2013 12:52 pm
bushman4 wrote:Not possible. Don't give the password to anyone you don't trust to only use Jukebox mode.
Glenn
Clear, but if i connect with an WP8 client I don't have an option to use Jukebox mode, when edit the player in Subsonic and change this to Jukebox the client won't play music on the server but on the WP8 device.
haribos
Postby bushman4 » Fri Apr 12, 2013 1:00 pm
Correct. Ask the creator of the Windows 8 application to add an option for Jukebox mode.
Or use the web interface on that Windows 8 machine...
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Users browsing this forum: No registered users and 58 guests
