OSX code signature invalid - causing firewall issues
Postby roversub » Mon Apr 15, 2013 4:20 pm
Normally on OSX 10.8 (Mountain Lion) the "Allow or Deny network connections for this software" dialog only shows up once- when the application is first launched. With Subsonic I have to click "Allow" every time I launch it. This sorta sucks if you're trying to run it on a remote sever. Anyway, I was told that this problem is usually caused by an invalid code signing certificate.
I checked this by running the following command in terminal:
codesign -vvv /Applications/Subsonic.app
Which returns:
invalid signature (ode or signature have been modified)
in architecture: i386
Uninstall / reinstall did not resolve the problem. Is there any way I can fix this, or is it just an issue with the application or installer?
roversub
Re: OSX code signature invalid - causing firewall issues
Postby jkstorer » Thu Apr 18, 2013 7:12 pm
I see the same thing, and my firewall is blocking requests to Subsonic even though it shows up in the enabled list. If I turn the firewall off, it works fine.
I've posted about it in this thread.
jkstorer
