Internal Error (error message included)
Postby cwojeski » Mon Apr 15, 2013 8:58 pm
Please help. Thank you in advance.
Error
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
Java version Oracle Corporation 1.7.0_05
Server jetty-6.1.x
Memory Used 62 of 127 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.MediaFileDao.getMediaFile(MediaFileDao.java:58)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:103)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:145)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61)
at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
... 65 more
cwojeski
