GJ51 wrote:It's probably your file structure.
X:\Music - defined in settings
Then that would contain a folder for each Artist so that the structure would look like
X:\Music\Artist\Album\Tracks
Example:
C:\Music\Beatles\Revolver\Taxman.mp3
This is the easy way to do it.
daneren2005 wrote:If by essentially exactly, you mean completely different, then sure it is
My best guess is that it just putting them in the order that they are found. It is most likely iterating over the folders in alphabetical order by genre since that is the root folder. I imagine it probably wouldn't be too hard to do a sort at the end (famous last words for any programmer, I know), but for we shall see if Sindre does it or not
ripley wrote:Is all your music tagged properly? If so I wonder if this is an issue with the tag handling by Subsonic.
