[Resolved] Error 503 on WinXP v4.6 & 4.8
Postby FreeMan » Sat Apr 20, 2013 5:33 pm
Hi all-
I've had 4.6 running for quite a while on my WinXP host, and had issues with 4.7 when it came out, so I reverted to 4.6. About a week or so ago, I started getting Error 503 when going to localhost:4040, and I couldn't connect from my Android client.
Finally, today, I decided to uninstall & reinstall, figuring that would do the trick, and that seemed to be the solution for the 4.7 issues people were having. I decided to check, and noticed that 4.8 was now available, so I installed that instead.
Unfortunately, I'm still getting Error 503 from the machine that subsonic is running on when I go to localhost:4040.
Image 2 shows that subsonic is actually started on localhost:4040.
Image 1 shows the error I'm getting (because nobody's ever seen a 503 before... :roll:)
The Server log is here: http://pastebin.com/6DrfJb9C It seems to me that at the end it says it's running.
Anybody have a suggestion of what may be wrong? Is there any additional information you need to dig into? I really like subsonic, and have been using it for years, and I'm disappointed that it's been non-functional for a week now.
FreeMan
FreeMan
Re: Error 503 on WinXP v4.6 & 4.8
Postby FreeMan » Fri May 24, 2013 3:10 am
Not a single suggestion? No tips, hints or things to check? Very disappointed - I've been using this great service for years, paid for clients and now, nothing.
FreeMan
Postby alphawave7 » Fri May 24, 2013 4:14 am
Try a complete uninstall/reinstall of java.
Postby FreeMan » Sat May 25, 2013 3:50 am
I uninstalled/reinstalled Subsonic - same error.
I uninstalled/reinstalled Java 7.21 - same error.
Sadness in Naptown
FreeMan
Postby GJ51 » Sat May 25, 2013 4:07 am
503 is a database error. Uninstall java, uninstall Subsonic through control panel, delete C:\Subsonic, reboot the host machine install java - latest version, install Subsonic, start all over form the beginning.
Sucks - don't it?
The weakest part of Subsonic is the lack of any protection for a database error. An improper shutdown is the most likely culprit that corrupts the db.
This has been written about 10k+ times - just use search: 503 error and you'll see you're not alone.
Pissed about losing all your data - users and history? Learn to back up the C:\Subsonic directory once a week so that you don't have to start from scratch next time.
Postby FreeMan » Sat May 25, 2013 4:14 am
Oy. Just went through all of that except I didn't uninstall both at the same time. Guess I'll do that.
Not really that upset about losing data/users/history - I have all the users & pwds stored (they're my kids, I get to know their passwords) in KeePass; data - it'll rebuild the database; history - meh, don't care what I've listened to last, just what's coming next.
Mostly just annoyed that I have to go through this. Usually I'm a bit more on the ball, not sure why it never occurred to me to search for "error 503" :oops:.
Thanks for the tip, GJ51.
Off I go again...
FreeMan
Postby GJ51 » Sat May 25, 2013 4:24 am
NP - let us know if you succeed. If you need more help I'm available on other channels - just send me a PM.
Postby FreeMan » Sat May 25, 2013 5:49 am
That seems to have done the trick. Trying Hakki's MediaCabinet fork, so we'll see how it goes.
Thanks again!
FreeMan
FreeMan
