Service will not start on my pc
Postby dbbarney » Mon Apr 22, 2013 7:52 am
I have a win 7 64 bit system Subsonic service 4.8 will not start. It has run properly in the past. When I try to start it I see a 1067 the process terminated unexpectedly. I have done nothing to my knowledge to change any settings on my computer that would keep it from starting. .
dbbarney
Re: Service will not start on my pc
Postby MadEvil » Mon Apr 22, 2013 9:14 am
Did you upgrade/install Java Version?
on a 64bit system with subsonic you need also the 32bit Java Runtime.
best regards
Madsonic Developer
MadEvil
Postby dbbarney » Mon Apr 22, 2013 10:52 pm
Thank you! Somehow that had gotten uninstalled.
dbbarney
