Java related bug with Subsonic 4.8
Postby pinesol » Thu Apr 25, 2013 10:31 pm
As soon as I upgraded and restored database from 4.7, entire left hand panel had this error message:
Error
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.7.0_10
Operating system Windows Server 2012 6.2
Server jetty-6.1.x
Memory Used 14 of 57 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:79)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:196)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:146)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61)
at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
Caused by: java.sql.SQLException: out of memory
... 64 more
First thought was that it updated improperly, so I removed c:\subsonic folder, removed Java (I had 1.7.0_21 installed) and installed fresh. First open, everything looked good, so I restored my database once more, and error came back. Even stranger, my mobile still sees all of my media, and can stream it just fine.
For now, I'll reinstall 4.7, but wanted to submit this to see if I can get it fixed somehow.
Michael
pinesol
Re: Java related bug with Subsonic 4.8
Postby pinesol » Thu Apr 25, 2013 10:44 pm
Edit. Even after reinstalling 4.7, error persists. Totally stumped now. I've tried several versions of Java and rebooted (of course) just to test.
pinesol
Postby transmobius » Thu Apr 25, 2013 10:56 pm
Just a guess - have you tried increasing the memory available?
http://forum.subsonic.org/forum/viewtopic.php?f=6&t=3939
transmobius
Postby pinesol » Thu Apr 25, 2013 11:19 pm
I did not. Never saw that option, though my error indicates that may have been the problem. For now, I've just created a new database. I still have a backup of the old one that I may try to restore using that. The only real issue with a new database is recreating my 25ish users.
Edit: Good thought. However, even when upping memory limit to 1 GB, same problem when database is restored.
pinesol
Postby gurutech » Fri Apr 26, 2013 2:22 am
This may help with recreating users:
:: Create Madsonic Acount ::
:: Create Madsonic Useraccounts
:: edit username/password/serverlink to your need
@echo off
set username=admin
set password=(your password)
set serverlink=http://yoursubsonic.subsonic.org
set /p user= "Username: "
set /p userpw= "Password: "
set /p useremail= "E-Mail: "
set wgetsettings=--spider --no-check-certificate --cookies=on --keep-session-cookies --save-cookies=%temp%\cookie.txt
.\bin\wget %wgetsettings% --user-agent=Mozilla "%serverlink%/login.view?user=%username%&password=%password%"
:: Create Custom (Prompted)
.\bin\wget %wgetsettings% --load-cookies=%temp%\cookie.txt --referer="%serverlink%" "%serverlink%/rest/createUser.view?u=%username%&p=%password%&v=1.8.0&c=remoteregister&username=%user%&password=%userpw%$&email=%useremail%&settingsRole=true&streamRole=true&jukeboxRole=false&downloadRole=false&uploadRole=false&playlistRole=true&coverartRole=false&commentRole=false&podcastRole=false&shareRole=true&commentRole=true&searchRole=true" >nul
gurutech
Users browsing this forum: No registered users and 58 guests
