Keeping user accounts when reinstalling
Postby wim.glenn » Sat Apr 27, 2013 1:49 am
I'm going to do a fresh reformat and install of Ubuntu 13.04 sometime soon ..
My subsonic server is working great on 12.10 the problem is I have some user accounts setup , and I can't just recreate them because I don't know my users passwords.
What is the correct way to backup and reinstate this information when doing a fresh install of OS and subsonic? I don't mind so much if the music library etc has to be rebuilded, but I do need to preserve the users - it should be transparent to them apart from an hour or two of downtime.
wim.glenn
Re: Keeping user accounts when reinstalling
Postby transmobius » Thu May 02, 2013 6:00 am
Take a look at /var/subsonic/db/subsonic.script, specifically the lines that begin with
INSERT INTO USER VALUES
INSERT INTO USER_ROLE VALUES
INSERT INTO USER_SETTINGS VALUES
The command
grep 'INTO USER' /var/subsonic/db/subsonic.script
should show you all of them.
Edit the file in the new install and drop them in.
NOTE: I have not done this, but it is what I would try myself, and no one else has replied.
transmobius
