Connection failure.
Connection failure.
Postby chefdwsaute » Tue Apr 30, 2013 2:51 am
Have been using Subsonic for quite some time and had very little issues. Today I was having problems with the computer and installed latest windows updates and newest java update. This is where I get error messages. Android app gives me the error "Connection failure. Didn't understand the reply. Please check the server address". If I try to connect to the server via my pc, I get the error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
Checked my router settings and nothing has changed. Don't understand why it won't even let me get to the server through the local host. Someone please help me. Thank you in advance!
chefdwsaute
Re: Connection failure.
Postby chefdwsaute » Tue Apr 30, 2013 3:00 am
can't even connect to localhost to log in anymore. don't know what happened.
chefdwsaute
Postby LoganSix » Wed May 29, 2013 1:42 am
I'm having the same issue.
I tried installing both 32 and 64 bit Java and then re-installing subsonic.
Still no luck.
LoganSix
Postby ruinerXIII » Wed May 29, 2013 3:45 am
This sounds similar to my issue. Another thread mentioned deleting the database and reinstalling fixes this, so I'm going to give that a try.
ruinerXIII
Users browsing this forum: Google [Bot] and 17 guests
