Can't access Subsonic at all
Postby chefdwsaute » Tue Apr 30, 2013 12:26 pm
Recent windows and java update made Subsonic unaccessible. Please help!
Everything was working fine until i did the update. Now, I cannot connect at all on either the Android app or my home computer. Computer says Subsonic is running but I get "error 503" when I try to open in browser. I get a "Connection failure. Didn't understand the reply. Please check the server address." when I try to connect via the Android app. I installed an older version of both Subsonic and Java, to no avail. I don't understand what happened, router settings still the same.
I've even gone as far as doing a brand new, clean Windows 7 install - also to no avail. What can be going on with this? Can't even access the server to check the log...
chefdwsaute
Re: Can't access Subsonic at all
Postby chefdwsaute » Tue Apr 30, 2013 9:12 pm
Solved my own problem. Installed both 32 bit and 64 bit Java and reinstalled Subsonic 4.6. That seemed to fix my issues for now. Thank you.
chefdwsaute
Postby LoganSix » Wed May 29, 2013 1:43 am
chefdwsaute wrote:Solved my own problem. Installed both 32 bit and 64 bit Java and reinstalled Subsonic 4.6. That seemed to fix my issues for now. Thank you.
I tried that, but it didn't work for me.
I'm running Windows 8.
LoganSix
Postby LoganSix » Wed May 29, 2013 2:00 am
Apparently deleting the Subsonic database and re-installing Subsonic fixes the error.
LoganSix
