alphawave7 wrote:If using Windows as your server, follow this tute and see how it goes:
viewtopic.php?f=6&t=4867
I'm guessing the part where I forward the ports. I did all the directions and then I go to canyouseemee.org and it says Reason: Connection timed outalphawave7 wrote:What part of that process fails? Have you tested your port against canyouseeme.org port tester?
Sent from my Nexus 4 using Tapatalk 2
alphawave7 wrote:Not wrong...just incomplete. The pic shows you've opened 8080 for INTERNAL passage..but you've left EXTERNAL unpopulated. Complete the external (right column) just as you have on the left, and you should be golden. Reboot after that change and test at canyouseeme.
alphawave7 wrote:Looks good. Reboot router and server...and make sure server firewall (windows) also has an exception for Subsonic on 8080.
Users browsing this forum: Google [Bot] and 17 guests
