without internet
without internet
Postby balazst » Fri May 10, 2013 1:59 pm
Dear All,
I'm new in this field, and maybe my question will sounds so stupid. So I would use Subsonic at my home network, I mean running on my PC as a server, and use my mobile to listen my favorit music but I want to use only wifi connection. Is it possible to set up my PC as a 'music streamer' with Subsonic using only wifi, and without any internet connection.
If yes what other services should I start on it, and how can I set up my iPhone if even possible.
I would use a TP Link MR3040 portable router.
Sorry if this question has already answered but I could not find anything in the topic about it.
Best regards
Balszst
balazst
Re: without internet
Postby rubbersoul » Fri May 10, 2013 6:29 pm
yes you can. not sure what you mean by other services, but you'll need an app called iSub on your iphone. you enter the lan ip address of your server into the isub app to tell it where to look.
rubbersoul
Postby balazst » Mon May 13, 2013 7:34 am
Thank you for the answer.
I tried application Substream because it was free.
I add my 'server' ip address, but it was not work.
I mean other services like web or ftp server or something like that.
Balazst
balazst
