OSX upgraded to newest, now cannot find way to change port
Postby binkleyz » Fri May 10, 2013 9:16 pm
The FAQ says to open the control panel, which works just fine, only I cannot see a way to change it. Clicking on what is there now (localhost:4040) opens up the Subsonic page just fine.
In my earlier install, I had it pointed to port 22220, which is what I want to keep the new version pointed to, but I see no way to modify that setting in either the web page or the control panel GUI.
I tried looking for a config file under the application package contents, but nothing in there.
what am I missing?
binkleyz
Re: OSX upgraded to newest, now cannot find way to change po
Postby binkleyz » Sat May 11, 2013 9:56 pm
So, NM, I found the file that needs to be modified.
That said, the install instructions could easily be made more clear.. Despite what the instructions say, opening the control panel does NOT provide a way to change the port configuration.
binkleyz
Postby alphawave7 » Sat May 11, 2013 10:46 pm
binkleyz wrote:So, NM, I found the file that needs to be modified.
Where does it say this in the Mac/OSX instructions?
http://www.subsonic.org/pages/installation.jsp#mac
The Control Panel port change is for Windows, so whatever source you read may be pointing to that version rather than Mac?
Users browsing this forum: Google [Bot] and 22 guests
