connecting via 3g not working, wifi works(not home)
Postby ramonlambal » Wed May 22, 2013 3:22 pm
I have used the search function on this forum but cannot find anyone with the same problem as I have.
My android phone cannot connect to my own subsonic server using 3g. When I enable wifi (even not at home, like in train, work or where-ever) it does work.
I found this quote(see down) and I followed all steps and can run through all steps without a problem.
more details:
phone galaxy s i9000 running CM10.1, newest stable update
License Subsonic Premium
Version 4.8 (build 3434) – April 17, 2013
Server jetty-6.1.x, java 1.7.0_21, Windows Server 2008 R2 (93.5 MB / 145.0 MB)
I CAN connect to the demo server over 3g
message on ramonlambal.subsonic.com(or at IP adres directly):
connection failure. Didn't understand the reply, please check the server adress.
Let's test this methodically... try each of these and let me know where it fails. Once it fails you don't need to continue on:
1. On the subsonic server, open
CODE: SELECT ALL
http://127.0.0.1:YourHTTPPort/YourContextPath
Does Subsonic open? If you log on, does it work?
2. On the subsonic server, open
CODE: SELECT ALL
http://Your.Server.Internal.IPAddress:Y ... ontextPath
3. On a different computer on the same network open
CODE: SELECT ALL
4. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
CODE: SELECT ALL
http://Your.Server.External.IPAddress:Y ... ontextPath
5. From outside the firewall (ie, from a computer NOT on your network, like a friend at his house) open
CODE: SELECT ALL
http://YourCustomDomainName.subsonic.org
6. From the subsonic server computer, open
CODE: SELECT ALL
Does Subsonic open? If you log on, does it work? if not, what address (if any) are you redirected to?
7. From a different computer on the same network as the Subsonic Server, open
CODE: SELECT ALL
Let us know where it fails.
ramonlambal
